04-28-2020 11:29 AM
I'm a student at a college and I keep getting issues in doing the ping and it works when i ping the devices in same switch but ı can't ping switches and other end devices. What is wrong with my setup ?
My project : https://ufile.io/wu7usl54
Solved! Go to Solution.
04-28-2020 11:56 AM
I have found two errors in your exercise.
1-The IP addresses of the end devices must match the network on which they are hosted.
For example, on the middle network the network is 192.168.5.0/24, but on end devices you assigned network IP 192.168.4.0/24.
The same error is in the network on the right.
2-In the router, the HWIC you used provides you with 4 switch ports, so the Fa0/1/0 interface must be associated with vlan 1, where you entered the gateway IP of that network.
R2(config)#interface vlan 1
R2(config-if)#no shutdown
R2(config-if)#interface fa0/1/0
R2(config-if)#switchport mode access
R2(config-if)#switchport access vlan 1
After these changes, connectivity is successful.
04-28-2020 11:54 AM
Dont have packet tracer to test.
but Looks like you have Routing issue, make sure ip routing enabled. and traceroute is good command for learning and tell you where it was dropped. so you can investigate from that point have routing in place.
04-28-2020 11:56 AM
04-28-2020 12:03 PM
09-20-2023 06:10 AM
sorry but when i type switchport commands on the router, it rejects it, i can't type switchport commands on that device
04-28-2020 12:00 PM
its homework?
redirect -https://learningnetwork.cisco.com/s/
I opened the file briefly and there are quite a few mistakes ... try to learn by asking specific questions rather than throw the whole thing for fix ..
- check interfaces connected on router are correct for the devices connect that interface
- check device default gateway and ip config - if device is 192.168.1.11 gw would be 192.168.1.x on router
