"Directed-broadcast" is not working!
Abdullah Net
Hello there,
I am testing enabling "directed-broadcast" in my network. I am using real cisco equipment in the topology below:
I have implemented static routings and Host A can ping Host C and Host D successfull and vise versa.
So, in HOST A,  i opened my windows cmd and i typed Ping 10.10.60.255 and i got:
Reply from 10.10.10.2: bytes=32 time=1ms TTL=254
That is normal because R2 by default drops all broadcasts and do not forward them. So, i enabled "Directed-broadcast" under R2 Int FA 0/1 which should allow directed broadcasts to be passed to 10.10.60.0/24 network. but i got the same replies
So, i opened wireshark on HOST A hoping to catch the problem and according to wireshark there is something wrong:
I got more into it and i enabled "debug i packed" and "debug ip icmp" on R2 and this is what i got:
IP: tableid=0, s=10.10.50.50 (Serial0/1/0), d=10.10.60.255 (FastEthernet0/1), routed via RIB
IP: s=10.10.50.50 (Serial0/1/0), d=10.10.60.255  (FastEthernet0/1), g=255.255.255.255, len 60, forward directed broadcast
IP: s=10.10.50.50 (Serial0/1/0), d=10.10.60.255 (FastEthernet0/1), len 60, rcvd 5
ICMP: echo reply sent, src 10.10.10.2, dst 10.10.50.50
IP: tableid=0, s=10.10.10.2 (local), d=10.10.50.50 (Serial0/1/0), routed via FIB
IP: s=10.10.10.2 (local), d=10.10.50.50 (Serial0/1/0), len 60, sending
I dont really understand what is the problem here. I also tried enabling "Directed-broadcast" on R2 int S 0/1/0 as well but i got same results.
Your help is appreciated...
Abdul,
10 Replies 10
Richard Burts
Abdul
This sounds like an interesting problem. Can you post the config of R2? This might help us to understand what is going on.
I find it surprising that your wireshark capture indicates that you are receiving an ICMP error protocol unreachable. But that the debug on R2 does not mention this at all.
Rick
Rick
I have looked more carefully at the wireshark capture and see some things that I missed the first time. What I am seeing is this:
- host A sends ping (as expected).
- R2 sends ping response (as expected).
- SW2 sends ping response - this demonstrates that directed broadcast on R2 is working.
- host A sends ICMP protocol not available to SW2 - quite unexpected.
So as far as directed broadcast is concerned it is working on R2. And it gets at least as far as SW2. If you are not receiving responses from host C or D then we may need to look more closely at the config of SW2 and see if it is doing something that affects the traffic.
Rick
Rick
Rick,
The configuration of SW2 is really basic and mostly standard. I only enabled Vlan 1 and gave it an ip address of 10.10.60.2 and that's it.
Abdul,
Jan Hrnko
Level 4
Level 4
Hi Abdul,
quite an interesting problem. Just one idea though, have you tried to check firewall settings on those hosts? Maybe firewall is blocking icmp traffic. Everything else looks normal.
Best regards,
Jan
Jan,
All firewalls are off and i double checked with your post.
Abdul,
can u post config
Jawad
Jawad
Abdullah Net
R1 Configuration
interface FastEthernet0/1
ip address 10.10.50.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0
ip address 10.10.10.1 255.255.255.252
clock rate 2000000
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
ip route 10.10.60.0 255.255.255.0 10.10.10.2
ip forward-protocol nd
access-list 100 permit icmp any any
R2 Configuration
Current configuration : 1012 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
archive
log config
  hidekeys
ip address 10.10.60.1 255.255.255.0
ip directed-broadcast
duplex auto
speed auto
ip address 10.10.10.2 255.255.255.252
clock rate 2000000
no ip address
shutdown
duplex auto
--More--
ip route 10.10.50.0 255.255.255.0 10.10.10.1
Abdullah Net
This is what i came up with so far. I replaced host C with a router (R3) and i gave its interface "fa 0/0" an ip address of 10.10.60.2.
I pinged 10.10.60.255 from host A and FINALLY i got a reply back
R1#
IP: tableid=0, s=10.10.60.2 (Serial0/0), d=10.10.40.1 (FastEthernet0/0), routed via RIB
IP: s=10.10.60.2 (Serial0/0), d=10.10.40.1, len 100, rcvd 4
According to wireshark, R3 recieved the icmp packet and issued a response.
So, i went and replaced back the router with HOST C as it was before and i opened wireshark to see whats happening and i got this:
HOST C did recieve the packet but did not issue a reply back.
Why is that? i replaced the PC with another one and i still got the same wireshark results.
Abdul,
have u defined gateway on our hosts
host c, d gateway must be
10.10.60.1
host a, b gateway must be
10.10.50.1
Jawad
Jawad,
Done that
Abdul,
