"SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input queue full" Error
recep_ali_sevim
I have a 6807-XL and nowadays device's cpu is using high CPU. I checked logging in the device and I saw this error. If I remove Snmp-server configuration from device, CPU work normally. But I need SNMP....
I run "show snmp" command. Maximum queue size is 1000 but there is 1200254 queue in the device.
How can I solve that problem? I found a solution but there are links have broken.
8 Replies 8
marce1000
 - Could be a bug , check current software version that the 6807 is using  , use an advisory release (if applicable) , check if  that can help.
 M.
I will check tomorrow and I will reply
balaji.bandi
How can I see thread numbers?
i mean many bugs reported. what is the version of code running ? check against ? or use snmpv2
BB
I checked snmp groups and I saw v1 and v2c
what does this mean? more explanation will be helpful here.
BB
post the output of:
sh ver
sh run
