"switch" frame depending on mac destination and source port
Toug31
I'am trying to make a CISCO 2960 configuration. This switch will be connected to equipment and an other network. I need it to switch the frames depending on 2 parameters.
First the mac destination of the frame. I know how to do it with the command
mac address-table static 0300.0000.1595 vlan 1 interface FastEthernet 0/23
for example.
But I need also to specify the source port of the cisco in the command because a frame with same dest mac may be received from 2 port and the receiver port will not be the same.
Something like
mac address-table static 0300.0000.1595 vlan 1 interface FastEthernet 0/23 source_port FastEthernet 0/21
mac address-table static 0300.0000.1595 vlan 1 interface FastEthernet 0/19 source_port FastEthernet 0/18
or if I could specify different vlan for each port, and not allowing frame to be switched between specific vlan?
hence I should see 2 different entries in the "show mac address-table".
Thanks.
If I understand what you're asking, you wish to switch a frame for the same destination mac address out of different switchports, conditional on the switchport the frame has come in on. The issue is that the mac address-table can only have one entry for a unique mac address reachable out a switchport per vlan
In your example static entries i notice you have two pairs of src/dst switchports.
1. if traffic towards dst mac 0300.0000.1595 is received on fa0/21 send out fa0/23
2. if traffic towards dst mac 0300.0000.1595 is received on fa0/18 send out fa0/19
If this is the case then you can put each pair of ports in a different vlan, which will allow you to have a static entry for the same mac-address per vlan. So switchports fa0/21 and fa0/23 are configured in vlan 1; switchports fa0/18 and fa0/19 in vlan 2. We don't need to worry about the source switchport now, as we have separated the switching between ports at L2.
Example:
mac address-table static 0300.0000.1595 vlan 2 interface FastEthernet 0/19
Hope this helps. Please rate if it does.
I'm not sure but I don't think that's possible. Groups of ports (ie vlan in your proposal) will not be always the same depending on the mac dest.
