RADIUS Authentication on 2960
challc2008
Wet setup MS IAS Server according to this article:
http://articles.techrepublic.com.com/5100-10878_11-6180954.html?tag=rbxccnbtr1
I still can't use my Active Directory user name and password to log into the switch. Any pointers ? Thank you.
dmcushing
Thank you for the reply, I have followed everything but its not working still.
How do I know which port?
ip radius source-interface f0/0
The ip radius source-interface command allows you to statically configure the source port or IP address for the outbound radius requests from your switch. Generally you would source this from your management VLAN or loopback interface.
HTH,
Mark
Latest update on this issue. I was able to see it in the logs that my user name is trying to authenticate but I was getting "Access Denied" because authentication protocols weren't matching. Do I need to specify some where in the switch to use PAP or PEAP?
