Random Phones Rebooting.
ubsaccount
%SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected
interface GigabitEthernet4/5
switchport access vlan 100
switchport mode access
switchport nonegotiate
switchport voice vlan 290
no logging event link-status
no snmp trap link-status
auto qos voip cisco-phone
storm-control broadcast level 1.00
qos trust device cisco-phone
spanning-tree portfast
spanning-tree guard root
service-policy input AutoQos-4.0-Cisco-Phone-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
We are having weird issues where phones randomly reboots.
andrewswanson
Level 7
Level 7
What is the output of the command show interface GigabitEthernet4/5 counters storm-control
hth
Andy
I checked physical and it doesn't seem like layer 1.  I don't see any errors on the interface.
Here are the outputs.  I really think it has something to do with Qos for some reason.
#test cab tdr int g3/28
#show cab td
#show cab tdr int g3/28
Interface Speed Local pair Cable length Remote channel Status
Gi4/5 1Gbps 1-2 54 +/-1m Unknown Open
3-6 53 +/-1m Unknown Open
4-5 54 +/-1m Unknown Open
7-8 54 +/-1m Unknown Open
Port Broadcast Multicast Level TotalSuppressedPackets
Gi4/ 5Enabled Disabled 1.00% 0
GigabitEthernet4/5  is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 3435.7374.3c5b (bia 3435.7374.3c5b)
Description: B1 F4 User Vlan 100
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is on, output flow-control is on
Auto-MDIX on (operational: on)
Last input 00:00:30, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 119369
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute output rate 6000 bits/sec, 5 packets/sec
204565655 packets input, 90406806812 bytes, 0 no buffer
Received 2182854 broadcasts (1568304 multicasts)
1001389137 packets output, 880251559573 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Why is this needed on the same interface?
Simoniscool
how often? and is it while in use or just all the time even overnight?
multiple phones or 1 phone?
show interface Gi4/5    -are there many CRC/input errors etc?
my first thought would be cable issues - I dont think the phone should reboot unless it loses power should it?
if compatible on your switch, you can sometimes see a cable problem stick out using:
test cab tdr int Gi4/5
and then:
show cab tdr int Gi4/5
you may need to do :
conf t
int Gi4/5
media-type rj45
to get it to work.
but some switches only test the TX and RX pairs not the PoE pair so it may not always show the problem
