Range of port in static NAT ??
TOR PRETORIUS
Is there any way I can set range of port in static NAT
I want open UDP port 5000-6006 to one IP inside.
exp:
This command open only tcp 1720
'ip nat inside source static tcp 10.80.150.10 1720 80.89.47.102 1720 extendable'
Thanks for your help.
Jon Marshall
In the search Netpro box type "nat port range".
Third entry down should answer your question.
Sorry i would link it but i can't seem to do it.
Jon
