Rapid PVST and "Edge Shr" state
gnijs
Level 4
Level 4
Hi all,
I have a port that is in "Edge Shr" state. I understand this is becuase it is running in half duplex mode.
This is because an (old!) device is connected with half-duplex NIC only.
The question now is:
* when there is a Topology Change (TCN), will this port be affected ? ie. will there be a rapid transition or not ?
According to the doc:
"RSTP can only achieve rapid transition to the forwarding state on edge       ports and on point-to-point links"
But does this mean that the port needs to be AND edge AND P2P ? Or is one condition enough ?
Note: that my port is an EDGE port, but not a P2P port ?
Do i gain something by configuring this port in P2P mode ?
regards,
Geert
The complete config of the port:
spanning-tree portfast bpdufilter default
interface FastEthernet1/0/2
power inline never
switchport access vlan xxxxx
switchport mode access
switchport port-security violation restrict
no snmp trap link-status
no mdix auto
storm-control broadcast level 5.00 3.00
storm-control action shutdown
storm-control action trap
spanning-tree bpduguard enable
end
#sh spanning-tree int fa1/0/2 detail
Port 4 (FastEthernet1/0/2) of VLAN0003 is designated forwarding
   Port path cost 100, Port priority 128, Port Identifier 128.4.
   Designated root has priority 8195, address 001a.3028.eac0
   Designated bridge has priority 32771, address 001b.90b7.fd80
   Designated port id is 128.4, designated path cost 4
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 7
   The port is in the portfast mode
  Link type is shared by default
   Bpdu guard is enabled
   Bpdu filter is enabled by default
   BPDU: sent 11, received 0
2 Accepted Solutions
Peter Paluch
Hello Geert,
If shared ports are both shared and non-edge, there will be no rapid transition. RSTP does not use the Proposal/Agreement mechanism on shared links, and will fall back to timers.
If a shared port is configured as an edge port (and is really connected to an end device), it will be rapidly put into Forwarding state as soon as it is connected, it will not generate TC events and will not be influenced by topology changes inside the network.
The RSTP is capable of rapid convergence on either point-to-point links or on edge ports.
Please feel welcome to ask further!
Best regards,
Peter
Mohamed Sobair
Level 7
Level 7
Just adding to Peter's Post, a rapid convergence occurs on either Point to point rstp link types and if the port is Edge port.
I will always set manually (Spanning-tree link-type point-to-point) on ports running on half duplex mode as a best practise, although its not required in Edge ports, but some times you may have ports that are not Edge ports , so you need to have this command applied on the ports running on half duplex mode to achieve RSTP rapid convergence.
Mohamed
Peter Paluch
Hello Geert,
Best regards,
Peter
Mohamed Sobair
Level 7
Level 7
Mohamed
