Rate limiting at vlan interface on Cat6509
tdennehy
Level 2
Level 2
I would like to rate limit the users on vlan 2099 - it is for guest users.  I have already put a filter on that vlan to limit the protocols and it works fine.  The rate-limiting does not work at all. Can someone tell if I am missing something? vlan access-map Filter_Guest 10 match ip address Guest_WLAN_Restriction action forward ! vlan filter Filter_Guest vlan-list 2099 ip access-list extended Guest_WLAN_Restriction permit udp any any eq bootps permit udp any any eq bootpc permit udp any any eq domain permit tcp any any eq domain permit udp any any eq 80 permit tcp any any eq www permit tcp any any eq 443 deny  ip any any interface Vlan2099 description = Dilbert_Development ip address 10.128.254.254 255.255.255.0 ip helper-address 123.123.133.1 ip helper-address 123.123.32.1 rate-limit input access-group 175 64000 8000 8000 conform-action transmit exceed-action drop rate-limit output access-group 175 64000 8000 8000 conform-action transmit exceed-action drop
27 Replies 27
Allen,
I just plugged in to gig5/2 on this 6509, configured the port and hit the bandwidth test site from my laptop and was unrestricted.
Te policy did not do anything to my knowledge. There is a FWSM in this 6509 which all traffic default-routes to. That's vlan 30. Traffic comes out on vlan 31, then goes out of the box on port channel 10. I'm thinking the QoS has to be placed on the vlan before it leaves for vlan 30, the default gateway. The traffic comes in to vlan 3099 from a WiSM that is in this chassis. Of course vlan 3099 is trunked, and the traffic flows normally from the laptop when connected to the wlan which is mapped to vlan 3099.
Why that would break it is beyond me, but it might? I'm at a loss as to where I would place 'mls qos vlan-based'. Sorry for the headache you are about to get...
Tim
firewall module 9 vlan-group 1
firewall vlan-group 1 30,31
vlan 30
name inside_fwsm
vlan 31
name outside_fwsm
interface Port-channel10
switchport
switchport trunk allowed vlan 31
switchport mode trunk
mtu 9216
no ip address
load-interval 30
mls qos
no mls flow ip
no mls acl tcam share-global
mls ip multicast flow-stat-timer 9
mls cef error action freeze
vlan 3099
name ELL_Dilbert_Development
class-map match-all RATELIMIT
match access-group name RATELIMIT
policy-map RATELIMIT
class RATELIMIT
police cir 64000000 bc 32000 be 32000 conform-action transmit exceed-action drop violate-action drop
interface GigabitEthernet5/2
switchport
switchport access vlan 3099
switchport mode access
no ip address
media-type rj45
interface Vlan3099
ip address 10.130.254.254 255.255.255.0
ip helper-address 129.237.133.1
ip helper-address 129.237.32.1
service-policy input RATELIMIT
service-policy output RATELIMIT
ip access-list extended RATELIMIT
permit ip any any
Hi Tim,
I think essentially as you are concerned with limiting traffic from the WiSM coming in on interface GigabitEthernet 5/2 within VLAN 3099, then this should be the inferace where you apply the 'mls qos vlan-based'.
Allan.
Hope this help, pls rate helpful posts.
Allen,
The gig port 5/2 is a copper port that I plugged my laptop in and placed it in vlan 3099 to test. The policy didn't work when I was hard wired in. Gig port 5/2 is a user port, not a trunk port. The WiSM creates a dynamic trunk that cannot be modified, so I don't know how I would place a command on a trunk port that is created automagically.
The problem still exists - I can't even get the laptop on gig5/2 to get policed. I placed the port in vlan 3099 and it is not restricted at all. There must be some other global command that I'm missing, I guess.
Tim
Hi Tim,
As Allen suggested, apply vlan-based under the physical interfaces. For testing purpose, you can lower the policer's cir, so that is easier to see the result.  Also vlan-based might not work on intra-vlan traffic; if you want restrict traffic within the vlan you might need to use user based or microflow policing.
HTH,
Lei Tian
My brain is full, so I'm going to have to pick this up on Monday.
Thanks for all your help so far.  You guys rock!
How do I rate helpful posts, by the way?
And thanks for all your help today.  I'm sure I'll get it figured out on Monday thanks to you!
Hi Tim,
Hmmm this is rather strange behaviour, I would expect service-policy on the SVI to be applicable to traffic on ingress from VLAN3099?  I assume the SVI 3099 is the default-gateway for VLAN3099 traffic from the WiSM?  If the PC was connected to this Gigabit5/2 interface as an access, then the ACLs applied on the SVI would take precedent and police the traffic accordingly with vlan-base qos applied to the interface?
As I'm not familiar with how the WiSM trunk interface is negotiated, an alternative would be to match the input-interface instead of a given as access-group as shown below.  However this requires mls qos vlan-based applied to interface as stipulate previously, whether the object match criteria is an access-group or particualr interface/trunk the behaviour or outcome should still be the same.
match input-interface GigabitEthernet5/2
class RATELIMIT
interface vlan3099
Rating posts is simply a case of clicking on the appropriate star to merit the level of helpfulness provided.
Allan
Allen,
I just put the following commands into the 6509, and plugged a laptop into gig7/11. Speed test indicates the policy is working one way... I can download at about 1.5 mb/s, but uploading to our bandwidth server is unrestricted. I figured I would fix it first going through the copper, then after I get it working, to look at the WiSM end.
Do you know if this is only supported one way? Sure looks that way...
Tim
class RATELIMIT
police 4000000 32000 32000 conform-action transmit exceed-action drop
interface GigabitEthernet7/11
switchport
no ip address
load-interval 30
interface Vlan3099
permit ip any any
What version of code?
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version
12.2(18)
System image file is
"sup-bootdisk:s72033-ipservicesk9_wan-vz.122-18.SXF11.bin"
Here's what I ended up with for a solution below. Basically, I could
not put "mls qos vlan-based" on the trunk port because it is a WiSM and
it is a dynamic trunk that is not configurable. So I ended up deploying
the policies on the vlans, 3099 is in the trunk to a wlan, and vlan 30
is the vlan that is the gateway to the FWSM - and eventually the
Internet. So it works. A wlan user on the SSID mapped to vlan 3099
gets policed to about 2mb/s, not 4mb/s as the policy is written.
Another thing I noticed is that when I plug my laptop into a copper port
on the 6509, I can only get a 1 mb/s connection to our bandwidth server.
Strange, but good enough for me.
I was thinking of taking an 8 port 3560 and trunking it to the 6509 and
placing the "mls qos vlan-based" command on that switch just to see if
it works. If not, I'll stick with what I have configured right now.
class-map match-all Identify_WLAN_Guest_outbound
match access-group name Guest_WLAN_UBRL_Outbound
class-map match-all Identify_WLAN_Guest_inbound
match access-group name Guest_WLAN_UBRL_Inbound
policy-map police_WLAN_Guest_traffic_outbound
class Identify_WLAN_Guest_outbound
drop
policy-map police_WLAN_Guest_traffic_inbound
class Identify_WLAN_Guest_inbound
drop
ip access-list extended Guest_WLAN_UBRL_Outbound
permit ip 10.130.254.0 0.0.0.255 any
ip access-list extended Guest_WLAN_UBRL_Inbound
permit ip any 10.130.254.0 0.0.0.255
interface Vlan3099
service-policy output police_WLAN_Guest_traffic_inbound (dnld police)
interface Vlan30
service-policy output police_WLAN_Guest_traffic_outbound (upld police)
If I understand your config statements correctly, you are defining the acl for the entire subnet and then policing per flow?   Not sure why it is capping at 2 instead of 4.
We are looking to do something similar, but for a larger address space.  I would love to get away with a single acl for the whole subnet.
Yes, I am doing the entire subnet.  It is working fine, actually
I did get different bandwidth results from what was configured, so I just bumped it up a bit until I got the desired bandwidth limitation and left it there.
