RE: 6509E Switch not able to boot into IOS
gilbertthor
hi,
When i restart the switch it will appear the error messages as below:
System Bootstrap, Version 7.1(1)
Copyright (c) 1994-2001 by cisco Systems, Inc.
c6k_sup2 processor with 262144 Kbytes of main memory
Autoboot executing command: "boot bootflash:c6sup22-js-mz.121-27b.E4.bin"
open(): Open Error = -9
loadprog: error - on file open
boot: cannot load "bootflash:c6sup22-js-mz.121-27b.E4.bin"
May i know what solution can overcome this.
Thanks.
Richard Burts
Gilbert
Does the file c6sup22-js-mz.121-27b.E4.bin exist in bootflash?
Rick
Rick
hi,
yes the file is in the bootflash:
thks
-Gilbert
This is another info that i capture from the switch while it fail boot into the IOS then it will fall to rommon.
rommon 1 > set
PS1=rommon ! >
PF_REDUN_CRASH_COUNT=0
CONFIG_FILE=
SLOTCACHE=cards;
BOOTLDR=
?=1
BSI=0
RANDOM_NUM=804049481
BOOT=bootflash:c6sup22-js-mz.121-27b.E4.bin,1
RET_2_RTS=06:34:40 UTC Fri May 16 2008
RET_2_RCALTS=1210919679
rommon 3 > boot
boot: cannot determine first file name on device "bootflash:"
rommon 4 > dir bootflash:
File size Checksum File name
Thank you.
-Gilbert
mbausenwein
hit control break on the boot sequence. Then do a dir bootflash: to verify if the file you are trying to boot is there. Sometimes this problem occurs when you try to boot a file either in the boot variables, or in the config that is not there.
