Re : Natting Q .....
sanjaynadarajah
I would like to confirm if the config for the natting below works or not :-
ip dhcp pool POOL
network 192.168.0.0 255.255.255.0
dns-server 203.121.65.39 203.121.65.30
default-router 192.168.0.200
lease 7
int e0/0
ip address 192.168.0.200 255.255.255.0
ip nat inside
int e0/1
ip address 192.168.1.200 255.255.255.0
ip nat inside
interface Serial0/0
ip address 200.x.x.x 255.255.255.252
ip nat outside
ip nat inside source list 10 interface s0/0 overload
access-list 10 permit 192.168.0.200 0.0.0.255
access-list 10 permit 192.168.1.200 0.0.0.255
Thank you,
Cheers,
- sn -
hennigan
Yes, it should work.
You'll want a default static route to the ip address on the other side of the serial link.
