Re: Switch Log !!!!
blissbilly
Community Member
Can anyone pls describe what is the exact detail specified by the sh log command on the
attached screenshot file of the cisco switch???
Santhosh K
cadet alain
what do you want to know exactly ?  the NTP  packets or what?
Regards.
Alain
johnlloyd_13
Level 11
Level 11
hi,
could you issue the 'show debug' command?
make sure you don't have any debugging enabled for NTP. use the 'undebug all' to disable this.
tmomani
Community Member
I dont think your gonna find an output with the how debug command. The logs are 1year 1weeks old
This is the output of "debug ntp packets" which shows the time details to be used. The same setting can be verified with "show ntp association details"
ref: reference time
org time:Originate time stamp.
rcv time:Receive time stamp.
xmt time :Transmit time stamp.
Cheers,
Tareq
