Re : To check on memory on switches/router ...
sanjaynadarajah
I would like to check how does one check if there is a memory issue on the switch/router ?
What commands can I use to check :-
i) memory leak
ii) buffer leak
iii) overall memory usage on the
router ....
I always use the 'sh processes memory' command to check on memory, which othe commands can supplement this to check on the switch/router memory ?
Router #sh processes memory
Total: 232163224, Used: 109466664, Free: 122696560
Thanking you in advance,
Cheers,
- sn -
Nagendra Kumar Nainar
You can use "show mem debug leaks" command to check the memory leak.
To check memory used by specific process, you can use "show memory summary"
HTH,
Nagendra
I am a curious guy, and went out writing the "show mem debug leak" command....
...and FREEZE my comnand line...
I opened another command line, to my main switch, and WOW....
"SW1#show processes cpu
CPU utilization for five seconds: 99%/100%; one minute: 80%; five minutes: 29%
Do it carefully :)
How do i resoved ? Clear line who performed the 1st command.
Best Regards,
Petrónio
Look at the "who" command to see who is connected on what line.
Look at the "disconnect" command options to disconnect a user connected through another line.
e.g.:
router#who
Line User Host(s) Idle Location
5 aux 0 Modem Autoconfigure 00:00:03
6 vty 0 idle 00:00:30 nms
* 7 vty 1 idle 00:00:01 nms
Interface User Mode Idle Peer Address
router#disconnect ssh vty 0
router#who
5 aux 0 Modem Autoconfigure 00:00:00
You may need to use different syntax if it's not an SSH connection (i.e.: use command help).
The other connection will likely timeout anyway, unless you have not configured timeouts for your lines.
Router_1#who
1 vty 0 idle 00:02:09 172.20.0.180 -- > This was the 1st connection ( Stucked ), before "disconnected"
* 2 vty 1 idle 00:00:07 172.20.0.180 -- > This was the 2nd connection i used for "disconnect" the previous one.
Router_1#clear line 1
[confirm]
[OK]
Best Regards,
Petrónio
