READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x07, component CPLD
I have a problema with my SG350XG
someone can help me
2147455954
2020-Jan-29 13:32:07
Warning
%STCK SYSL-W-UNITTRP: UNIT ID 2,Trap:%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0d, component CPLD
2147455965
2020-Jan-29 10:39:55
Warning
%STCK SYSL-W-UNITTRP: UNIT ID 2,Trap:%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0f, component CPLD
2147455967
2020-Jan-29 10:31:03
Warning
%STCK SYSL-W-UNITTRP: UNIT ID 2,Trap:%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x07, component CPLD
2147455968
Warning
2147455970
2020-Jan-29 10:15:12
Warning
%STCK SYSL-W-UNITTRP: UNIT ID 2,Trap:%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x08, component CPLD
2147455972
2020-Jan-29 10:01:32
Warning
2147455973
Warning
2147455974
2020-Jan-29 09:47:56
Warning
2147455979
2020-Jan-29 08:40:50
Warning
%STCK SYSL-W-UNITTRP: UNIT ID 2,Trap:%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0e, component CPLD
2147455989
2020-Jan-29 06:18:18
Warning
%STCK SYSL-W-UNITTRP: UNIT ID 2,Trap:%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x09, component CPLD
2147455990
Warning
2147455991
2020-Jan-29 06:04:51
Warning
There is newer software available, you could try upgrade switch firmware to fix the problem
https://software.cisco.com/download/home/286282283/type/282463181/release/2.5.0.92
6 Replies 6
Mark Malone
thats a bug ,is there a version ahead to upgrade too ?
whats your current version ?
Hi,  the version of my switch is 2.4.0.91
wigo4it_admin
I we have version 3.1.0.57 but we still have this issue on one of our switch in a stack of 2 CBS350-24XS. Any clue?
MichalZ
Version: 3.3.0.16
Same issue.
djtech2k
I have the same issue, along with more similar errors.  I have tried 3.3.0.16 and 3.2.0.89 firmware and same result.  Mine seems to happen at random times but I think it more consistently happens when I plug in my Cisco copper SFP's (SFP-10G-T-X).  Most of the time I plug in one of these SFP's my switches start repeating these errors and when looking at the diagnostic page, the port information shows as unavailable and the web portal ends up freezing, and the switch reboots itself.
