recommend switch with routing capability
alankiecker
Community Member
Please recommend a switch that also has routing capabilities.
Jason Fraioli
Level 6
Level 6
3550, 3750
Giuseppe Larosa
Hello Alan,
you haven't described the use you want to do for this multilayer switch.
if you are interested in a device able to perform inter-vlan routing the starting point can be:
C3560
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swintro.html#wp1575289
you can use the following document as a starting point
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/switchperformance.pdf
Hope to help
Giuseppe
Thankyou.
We have a controller that sends packets to multiple IP addresses. We need to route these packets to the switch ports depending on the destination IP address.
