Recovering a Cisco 9600R
carl_townshend
Hi All
I am working on some DR documentation for the recovery of a cat 9606R switch with dual supervisors running in stackwise virtual, quad sup
I need to imagine a failure of one of the chassis for example where they wont boot and I have been delivered 2 new sups.
Am I right in saying first, it would be a good idea to disconnect the stackwise links, not to affect the other chassis?
Once recovered, would I need to covert to stackwise and then copy the config from the primary, how would we reintroduce back to the pair without downtime?
Has anyone got any info on this?
cheers
balaji.bandi
Follow below guide replacement of failed one :
https://www.cisco.com/c/en/us/support/docs/interfaces-modules/catalyst-9600-series-supervisor-engine-1/216193-replace-a-supervisor-module-or-stack-mem.html
1. make sure you plan correctly write the steps.
2. make sure take the config backup out of the box.
3. new sup need to same version of code
BB
5 Replies 5
balaji.bandi
BB
Leo Laohoo
IF the chassis dies then the StackWise links are dead anyway.
Besides, dual-sup and each chassis has multiple power supplies.  The only thing that can fail is the backplane and I've only seen one Catalyst 6k with a faulty backplane.
Make sure the power supplies are fed by a power rail which can be "controlled" via IP.  My worst case "nightmare" scenario is split brain to this kind of network equipment housed in a public DC which requires 48-hour notice just to gain access.
@Leo LaohooI am working on C9606R (in Lab) and I am stuck into split brain and trying since 3 hours to get my switches back in SVL.
I have checked both the Switch configs, these are:
Switch_1#
en
switch renumber 1
switch priority 15
configure terminal
 boot system bootflash: xxxxxxxxxx.bin
stackwise-virtual
 domain 4
 end
wr
Switch_2# same config with priority 14
Switch 1 rebooted first and after 5 to 10 seconds Switch 2 is rebooted
Port 1 and 25 on both are configured for SVL and Ports 4 and 28 are configured as is configard for DLD. Config is right.
During restart both the Switches Say:
Waiting for remote chassis to join
###############################################  but both come up as standalone.
I have restarted both for like multiple times and they are not joining the Stack. Its a Split Brain.
What can I do to get them back? The clock is ticking... and any help I can get will be a light in the darkness
Thanks in advance.
post show run from both the device removing confidential information to help. (if this is impacting contact tac is best to resolve)
Make sure check the Physical port come up and working ?
post below output also :
show stackwise-virtual
show stackwise-virtual link
show stackwise-virtual dual-active-detection
BB
zeeshandeu85411
As I was working in Lab Environment so in my Case the solution was:
The config was removed on both the Switches and they were configured again.
Switch 1#
en
switch renumber 1
switch priority 15
configure terminal
boot system XXXXXX.bin
stackwise-virtual
domain 4
end
wr
!!! Same config on Switch2 only with lower Priority !!!
!!! After Reboot, Configration on Switch1 !!!
interface range TwentyFiveGig1/1/0/1, TwentyFiveGig1/1/0/25
description Stackwise-Virtual Link SW2
stackwise-virtual link 1
interface range TwentyFiveGig1/1/0/4, TwentyFiveGig1/1/0/28
description Dual-Active-Detection Link SW2
!!! After Reboot, Configuration on Switch2 !!!
interface range TwentyFiveGig2/2/0/1, TwentyFiveGig2/2/0/25
description Stackwise-Virtual Link SW1
interface range TwentyFiveGig2/2/0/4, TwentyFiveGig2/2/0/28
description Dual-Active-Detection Link SW1
wr
!------ Reboot Switch 1 and after a couple of seconds Reboot Switch 2 ----------!
!------ Don't Press Any Key, give them extra time to come back completely -----!
!!Now they should become a pair!!
!!You will not be able to logon to Switch 2, or if you can Login you will see this message:
"Standby console disabled"
Verify with show commands:
Switch1#
show switch
