Recovering after a Factory Reset on a 9300 series switch
Sparkeyluv
I had no other choice but to do a factory reset on my 9300 series 48 port switch. I’m now posting to figure out my next steps.
The first thing I tried from the switch: prompt was to copy usbflash0:image bootflash: unfortunately after entering this command I get the error “write access to bootflash: unsupported”
The next thing I tired to do was from the switch: prompt flash_init but revived an error “command “flash_init” not found”
and finally from the switch: prompt I did a boot usbflash0:image. After the switch rebooted and into the image I tried to do a copy usbflash0 to bootflash that appeared to work and then a wr. But after rebooting found nothing “stuck”. And now I’m back at step one.
Any help I getting this switch up and running is gladly and happily appreciated.
Leo Laohoo
When a Catalyst 9k switch is in ROMMON, it is not possible to copy the firmware from the USB into the flash.  It is locked down.
If the switch was factory-reset, then the recommended method of putting the firmware back into the switch is to use the command "emergency-install usbflash0:IOS_filename.bin".
marce1000
                  >...I tried to do a copy usbflash0 to bootflash that appeared to work
     - A rather mysterious sentence because you can't copy the usbflash device to the bootflash device , could you clarify ?
 M.
Leo Laohoo
Question, how did you know this and where could I have found this listed at?
It is an "undocumented feature".
I found out about it because it is part of my job to do some "unboxing" tests.
