Recovering an Switch from bin prompt with empty flash
Muhammed Adnan
Level 4
Level 4
Dear Experts,
I have a 3560G switch with 48 ports. I had mistakenly reloaded with switch, without taking into consideration of fact that someone has already deleted the flash and saved the config. After reload, when the switch returned to bin prompt, I tried booting it only to get the surprise of flash as already empty:(
 As the flash is now empty, is there any way out that I could be able to load the image onto Cisco flash? I need to bring this switch into working condition asap.
Would appreciate any help in this regards.
switch: dir flash:
Directory of flash:/
32513024 bytes available (1024 bytes used)
switch: set
BOOT=c3560-ipbasek9-mz.122-55.SE9.bin
CLEI_CODE_NUMBER=CNMWY00ARB
MAC_ADDR=00:18:19:AD:43:80
MODEL_NUM=WS-C3560G-48TS-S
MODEL_REVISION_NUM=C0
MOTHERBOARD_ASSEMBLY_NUM=73-9358-04
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FOC102244SQ
POWER_SUPPLY_PART_NUM=341-0107-01
POWER_SUPPLY_SERIAL_NUM=AZS1021011G
SDM_TEMPLATE_ID=0
SFP_MODULE_BOARD_ASSEMBLY_PART_NUM=73-7757-03
SFP_MODULE_BOARD_REVISION_NUM=A0
SFP_MODULE_BOARD_SERIAL_NUM=CAT10171LR6
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FOC1022Y2G9
TAN_NUM=800-25428-02
TAN_REVISION_NUMBER=B0
VERSION_ID=V02
switch:
Thanks and Regards,
Adnan
InayathUlla Sharieff
Adnan,
Try this:
switch:dir flash:
switch:flash_init
Switch:load-helper
Switch:boot flash:filename/filename
Ref:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
https://supportforums.cisco.com/message/3837901#3837901  >> To boot the device from Xmodem  --switch:
https://supportforums.cisco.com/thread/2128878   >> To boot the device from TFTP from switch:
http://www.freeccnaworkbook.com/workbooks/ccna/recovering-a-corrupt-cisco-ios-image-on-a-catalyst-switch >>> Good link which explain step by step
Inayath
************Plz rate if this info is helpfull****
Dear ivaideanu , Inayath,
Thank you for your prompt responses.
And yes, terminal emulator came in handy. From terminal emulator was able to transfer the image via console port to Switch's flash. After booting it came up fine perfectly.
Thanks and Regards,
Adnan
Iulian Vaideanu
Level 4
Level 4
xmodem may be your only friend here:
https://supportforums.cisco.com/discussion/10319446/how-upload-ios-3560-switch
