Red X on Network drives and Unknown Publisher when running apps after VLAN config
mjaworske
We have been running the SG500-52P switches (2 switches stacked) for 2 years with No issues. We recently moved our office and added a new VoIP phone system. We had some trouble getting everything installed originally but its all working now with this one pesky problem. After putting the switches in Layer 3 mode, adding a VLAN for the phone system and setting up a route between VLAN1 (data) and VLAN2 (phones). We are now having this problem: Users are randomly getting Red X's showing disconnected network drives. There appears to be no pattern to when the disconnect happens. It can happen almost instantly after a reboot or sometimes be fine for a few days before disconnecting.  If you click on the drives you can access the data but the Red X DOES NOT go away. Although when accessing some applications we get an "Unknown Publisher" message and usually the program crashes. All our Workstations are Win 7 Pro and Servers are 2008 R2. We map server and NAS drives, when the issue happens is disconnects all the mapped drives and NOT just one server.
Reza Sharifi
Definitely not a good situation to be in, as you never know who will call and complain of loosing connectivity.  Have you opened a ticket with TAC?
Unfortunately we don't get a lot of comments/questions on the SG series here.
