RedEarth Tx Mana - High CPU usage on Cisco 3560-X
mmendis
Hi Everyone,
We are doing a testing on Cisco 3560-X switch by generating 100M traffic. Now CPU usage of RedEarth Tx Mana
is high around 40%.
We have tweak the SDM templates for routing.
Can any one help to sort this out ??
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:34 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
NMC-0.77-3560 uptime is 1 day, 1 hour, 42 minutes
System restarted at 09:34:34 LKR Thu Aug 22 2013
System image file is "flash:/c3560e-universalk9-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipservices
License Type: Evaluation
Next reload license Level: ipservices
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1622R1X9
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : D8:67:D9:CA:0D:80
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3560X-24T-L
Top Assembly Revision Number    : E0
Version ID                      : V02
CLEI Code Number                : COMJU00ARB
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       12.2(58)SE2           C3560E-UNIVERSALK9-M
Configuration register is 0xF
10 Replies 10
Leo Laohoo
Version 12.2(58)SE2
This is most likely your culprit.
Use 12.2(55)SE8 if you are running Layer 3, PoE and/or 802.1x.
You could also try 15.0(2)SE4 although I'd much prefer 12.2(55)SE8.
Hi Leo,
Is this one will work ?
c3560e-universalk9-tar.150-2.SE4
Without knowing what you've got, give it a try.
I have tried with the new IOS , still the same issue.
Do you have the following:  Layer 3 operation, PoE or 802.1x.
If you have any one of the above, then try 12.2(55)SE8.
mmendis
Is there any other work round to tackle the RedEarth Tx Mana high utilization issue ??
I have same issue with our  WS-C3750X-48 running  15.0(2)SE3 [c3750e-universalk9npe-mz.150-2.SE2] IOS.
------------------show process memory-------------------
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
  89   0          0          0       7200          0          0 RedEarth I2C dri
  90   0      34872      34816       7160          0          0 RedEarth Tx Mana
  91   0      28600      35368       7160       2268          0 RedEarth Rx Mana
------------------ show process cpu ------------------
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  89      545506     2571645        212  0.15%  0.20%  0.17%   0 RedEarth I2C dri
  90     9762656     1715940       5689  2.24%  2.46%  2.55%   0 RedEarth Tx Mana
  91       93631     1285767         72  0.00%  0.01%  0.00%   0 RedEarth Rx Mana
Please advice!!!
This HIGH CPU Usage might be due to TCAM Exhaustion. In our case we saw the same in our 3560 used in Router Mode with BGP + OSPF.
Use this command to check the utilization of TCAM.
show platform tcam utilization
You will get similar Output :
sh platform tcam utilization
CAM Utilization for ASIC# 0                      Max            Used
                                             Masks/Values    Masks/values
Unicast mac addresses:                       2268/2268         39/39
IPv4 IGMP groups + multicast routes:         1072/1072          1/1
IPv4 unicast directly-connected routes:      2048/2048         34/34
IPv4 unicast indirectly-connected routes:    2048/2048       2047/2047
IPv6 Multicast groups:                       1072/1072         11/11
IPv6 unicast directly-connected routes:      2048/2048          0/0
IPv6 unicast indirectly-connected routes:    3072/3072          3/3
IPv4 policy based routing aces:               128/128          13/13
IPv4 qos aces:                                512/512           6/6
IPv4 security aces:                           640/640          44/44
IPv6 policy based routing aces:               128/128           8/8
IPv6 qos aces:                                128/128           5/5
IPv6 security aces:                           128/128          17/17
Note: Allocation of TCAM entries per feature uses
a complex algorithm. The above information is meant
to provide an abstract view of the current TCAM utilization
in our testing the above high utilization of "IPv4 unicast indirectly-connected routes:    2048/2048       2047/2047"was the issue that high CPU usage occour.
As we have found, Router will forward packet to CPU when TCAM resources are full. We didn't found a good explanation for this, but i hope this will give you some idea.
  Unicast mac addresses:                       6364/6364         189/189
IPv4 unicast directly-connected routes:       6144/6144          0/0
IPv4 unicast indirectly-connected routes:     2048/2048         34/34
IPv6 Multicast groups:                         112/112          11/11
IPv6 unicast directly-connected routes:         74/74            0/0
IPv6 unicast indirectly-connected routes:       32/32            3/3
IPv4 policy based routing aces:                412/412          12/12
IPv4 qos aces:                                 512/512          21/21
IPv4 security aces:                            924/924          44/44
IPv6 policy based routing aces:                 18/18            8/8
IPv6 qos aces:                                  22/22           18/18
IPv6 security aces:                             60/60           17/17
I do not see any thing abnormal here. Can you please advice from the above command ?
Seems like any of your TCAM resorces are not much utilized. I did not find any good explanation about what RedEarth Rx Mana process actually does.
Better do some more search on this process.
