09-17-2015 06:18 AM - edited 03-08-2019 01:49 AM
Hi All,
Actually, the main idea it's advertise a subnet with another metric to WAN link.
So, we've created the script below, but it didn't work. It has done on 4948 switch with 122-54.SG version and EIGRP protocol.
Obs.: This subnet 10.11.99.0/26 is announced by another switch.
sh ip eigrp topology 10.11.99.0/26
EIGRP-IPv4 Topology Entry for AS(8)/ID(10.11.11.194) for 10.11.99.0/26
State is Passive, Query origin flag is 1, 2 Successor(s), FD is 3584
Descriptor Blocks:
10.11.10.237 (Vlan1201), from 10.11.10.237, Send flag is 0x0
Composite metric is (3584/3328), route is Internal
Vector metric:
Minimum bandwidth is 1000000 Kbit
Total delay is 40 microseconds
Reliability is 255/255
Load is 26/255
Minimum MTU is 1500
Hop count is 3
Originating router is 10.11.11.198
10.11.11.10 (Vlan1800), from 10.11.11.10, Send flag is 0x0
Vector metric:
Load is 26/255
Minimum MTU is 1500
Hop count is 3
access-list 20 permit 10.11.99.0 0.0.0.64
route-map NET permit 10
match ip address 20
set metric 128 200 255 1 1500
route-map NET deny 20
<On EIGRP>
distribute-list route-map NET out g1/42
09-17-2015 06:55 AM
I had the same problem some days ago. I found out, that it seems to be only possible to increase the metric, not to decrease the metric.
You can increase the Bandwidth, the Delay, the Load and the Reliability, but you cannot change the RD directly.
Maybe they did for reasons of loop prevention...
09-17-2015 08:04 AM
Hello
What actually are you trying to accomplish - unequal load sharing - if so this can be acheived by eigrp compositic metric calculations which you can in fact apply a load share value you wish?
res
Paul
09-17-2015 08:05 AM
Hi Paul,
I was trying redistribute the route with a worse metric.
09-17-2015 08:13 AM
Hello
So to have a preffered route or to load share with a definative value?
res
Paul
09-17-2015 09:38 AM
09-18-2015 05:16 AM
Hello
Apologies I am still unclear what you’re trying to establish - however looking at the diagram you posted
Remote site:
1)
to prefer a certain path for a specific network can be accomplish by a distance command relating to a ACL for the preferred prefix.
2) If you wish to do this for all traffic then the distance or delay command can accomplish this
Data centre perspective:
you can utilize eigrp compostic metrics for unequal load sharing for all traffic
or
Possibly if applicale summarise the prefix from either DC and then leak the more specific route from preferred DC
res
Paul
09-17-2015 10:10 AM
Please, take a look the attached file.
I would like to redistribute it on DC1 with a worse metric to become the Wan in DC 2 like active.
09-17-2015 10:16 AM
