Redistribute BGP into OSPF
rraver
We are multi-homing between two different providers on two seperate routers. We want to redistribute BGP routes into OSPF, we have done this and it works but the default route that we get from the carrier isn't going into OSPF. I have put in both the default-information originate command and the redistribute bgp **** command. Is there any trick to get it to inject the default route as well? We want to do this so that the layer behind it can intelligently select what default gateway to choose based on the circuit being up or down.
royalblues
Level 10
Level 10
Default-information originate should advertise a default route into your campus if there is a default route entry in the routing table i.e if the route is learned from BGP
Can you post sh ip bgp and sh ip ospf da external from the router connecting to your carrier?
Narayan
