Redistribute connected -- Eigrp
mahesh18
Level 7
Level 7
Hi Everyone,
Need to confirm use of command redistribute connected  while using between 2 Routers which are Eigrp Neis
R1  is Running EIGRP  and OSPF.
It is nei to R3 which is also running EIGRP and OSPF.
I am using redistribute command under EIGRP only
R1 Config
router eigrp 100
network 13.13.13.1 0.0.0.0
network 100.100.100.100 0.0.0.0
network 101.101.101.101 0.0.0.0
no auto-summary
2691Router# sh run int loopback 6
Building configuration...
Current configuration : 95 bytes
interface Loopback6
description Tunnel0 Source IP
ip address 10.0.0.1 255.255.255.255
end
    sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            70.x.x.100    YES DHCP   up                    up
Serial0/0                  192.168.1.1     YES NVRAM  down                  down
FastEthernet0/1            192.168.5.3     YES NVRAM  up                    up
FastEthernet1/0            192.168.6.3     YES NVRAM  up                    up
Serial1/0                  192.168.2.1     YES NVRAM  down                  down
FastEthernet1/1            192.168.7.1     YES NVRAM  administratively down down
Serial1/1                  192.168.9.3     YES NVRAM  down                  down
NVI0                       unassigned      NO  unset  up                    up
Loopback2                  2.2.2.2         YES NVRAM  up                    up
Loopback3                  3.3.3.3         YES NVRAM  up                    up
Loopback4                  4.4.4.4         YES NVRAM  up                    up
Loopback6                  10.0.0.1        YES manual up                    up
Loopback7                  100.100.100.100 YES manual up                    up
Loopback8                  101.101.101.101 YES manual up                    up
Loopback33                 unassigned      YES TFTP   up                    up
Loopback133                unassigned      YES TFTP   up                    up
Tunnel0                    13.13.13.1      YES manual up                    up
2691Router#
R1 has Tunnel connection to R3
R3 config
              sh ip route eigrp
     2.0.0.0/24 is subnetted, 1 subnets
D EX    2.2.2.0 [170/297372416] via 13.13.13.1, 04:59:12, Tunnel0
     100.0.0.0/32 is subnetted, 1 subnets
D       100.100.100.100 [90/297372416] via 13.13.13.1, 4d19h, Tunnel0
     70.0.0.0/22 is subnetted, 1 subnets
D EX    70.0.0.0 [170/297246976] via 13.13.13.1, 04:59:12, Tunnel0
     3.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
D EX    3.3.3.0/24 [170/297372416] via 13.13.13.1, 04:59:12, Tunnel0
     101.0.0.0/32 is subnetted, 1 subnets
D       101.101.101.101 [90/297372416] via 13.13.13.1, 4d19h, Tunnel0
     4.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D EX    4.4.4.0/24 [170/297372416] via 13.13.13.1, 04:59:12, Tunnel0
So  on R3 we see routes for Loopback 2,3,4  as External routes in  R3
Its also showing Fa0/0 Route as external.
My question is when we use redistribute connected under EIGRP ----
    then  does  it redistribute all loopback and fast ethernet  interface IP addresses of that router?
it will exclude the connected interfaces of R1 which are used by other routing protocols like ospf right?
In this case R1 interface IP 192.168.5.3 and 4.3 which are running ospf and redistribute connected does not redistribute these addresses to R3 as these routes are used by OSPF right ?
LAst thing to know is why redistribute connected on one router shows route as D  EX   on other Routers  even though they are from Same routing
protocol EIGRP ?????Does it because we do not use network command under EIGRP ?????????????
MAhesh
6 Accepted Solutions
Nagendra Kumar Nainar
When routing protocol A is redistributed into routing protocol B, it is basically a 2 step process a sbelow,
1. Redistribute all prefixes from RIB (routing table) which are learnt from A.
2. Redistribute all connected interface which are enabled with A.
Skip step 2 if you have "redistributed connected" already enabled under routing protocol B.
In your case, when you have OSPF redistributed into EIGRP, it will redistribute all OSPF learnt route from routing table (step 1) and all interfaces whcih are enabled with OSPF (step2).
HTH,
Nagendra
Per your confi (provided in the query), you have redistributed connected under eigrp. So all connected interface will be redistributed into EIGRP.
-Nagendra
Reza Sharifi
Hi Mahesh,
As soon you use the redistribute connected all connected interfaces will get redistribute it
correct
In  this case R1 interface IP 192.168.5.3 and 4.3 which are running ospf  and redistribute connected does not redistribute these addresses to R3  as these routes are used by EIGRP right ?
correct
Correct, is you use the network command the neighbor routers sees it as internal EIGRP (90) when you use redistribute connected the neighbor router sees it as external (170)
Reza
On R1, you have OSPF enabled on loopback interface (3.3.3.3/24 and 4.4.4.4/24). By default, the network type for loopback interface on OSPF will be loopback which will advertise it as /32 irrespective of the actual mask you have configured.
In this case, R3 is receiving 3.3.3.3/32 and 4.4.4.4/32 (the mask is not /24) via OSPF while it is receiving 3.3.3.0/24 and 4.4.4.0/24 via EIGRP from R1.
So it installs ospf learnt /32 and EIGRP learnt /24 in RIB.
If a prefix of exact mask match is received from different protocol, AD will be considered. But if the mask is different, it will be tretaed as different prefix and will install bth as in your case.
HTH,
Nagendra
Hi Mahesh,
If you want to see only the EIGRP router do a
sh ip route eigrp
If you want to see only the OSPF router do a
sh ip route OSPF
When you do
sh ip route,
it will show everything.
Reza
Second thing need to confirm is that OSPF always advertise Loopback interface as /32 mask right?
Yes. That is the default behaviour. You can change it by configuring "ip ospf network point-to-point" under loopback interface. This will make OSPF to advertise with actual mask (as configured in loopback).
HTH,
Nagendra
12 Replies 12
HTH,
Nagendra
Hi Nagendra,
I am redistributing between EIGRP processes not between EIgrp and OSPF.
Mahesh
-Nagendra
Reza Sharifi
Hi Mahesh,
correct
correct
Reza
Hi REza,
Thanks for reply.
But R3 router shows same route learned by OSPF  and EIGRP  from R2 and R1.
Here is more info
I have R1 connected to R3 by GRE Tunnel.
R1 is running EIGRP and OSPF.
R3 is also running EIGRP and OSPF.
R1 has OSPF connection to R2.
R2 has OSPF connection to R3.
R1 Config
router eigrp 100
no auto-summary
router ospf 1
router-id 4.4.4.4
log-adjacency-changes
redistribute static metric 300 subnets
passive-interface Serial0/0
passive-interface Serial1/1
network 3.3.3.3 0.0.0.0 area 0
network 4.4.4.4 0.0.0.0 area 0
network 10.0.0.1 0.0.0.0 area 0
When i do sh ip route
On R3 it shows
  sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.4.2 to network 0.0.0.0
     200.200.200.0/32 is subnetted, 1 subnets
C       200.200.200.200 is directly connected, Loopback1
     201.201.201.0/32 is subnetted, 1 subnets
C       201.201.201.201 is directly connected, Loopback2
D EX    2.2.2.0 [170/297372416] via 13.13.13.1, 07:45:42, Tunnel0
D       100.100.100.100 [90/297372416] via 13.13.13.1, 4d22h, Tunnel0
D EX    70.0.0.0 [170/297246976] via 13.13.13.1, 07:45:42, Tunnel0
O       3.3.3.3/32 [110/3] via 192.168.4.2, 02:11:20, FastEthernet0/0
D EX    3.3.3.0/24 [170/297372416] via 13.13.13.1, 07:45:42, Tunnel0
O       3.4.4.4/32 [110/2] via 192.168.4.2, 02:11:20, FastEthernet0/0
O    192.168.30.0/24 [110/2] via 192.168.4.2, 02:11:20, FastEthernet0/0
D       101.101.101.101 [90/297372416] via 13.13.13.1, 4d22h, Tunnel0
     64.0.0.0/32 is subnetted, 1 subnets
O E2    64.59.135.150 [110/300] via 192.168.4.2, 02:11:20, FastEthernet0/0
O       4.4.4.4/32 [110/3] via 192.168.4.2, 02:11:20, FastEthernet0/0
D EX    4.4.4.0/24 [170/297372416] via 13.13.13.1, 07:45:42, Tunnel0
     20.0.0.0/32 is subnetted, 1 subnets
C       20.0.0.1 is directly connected, Loopback0
O    192.168.10.0/24 [110/2] via 192.168.4.2, 02:11:20, FastEthernet0/0
     172.31.0.0/24 is subnetted, 4 subnets
O E2    172.31.3.0 [110/300] via 192.168.4.2, 02:11:20, FastEthernet0/0
O E2    172.31.2.0 [110/300] via 192.168.4.2, 02:11:20, FastEthernet0/0
O E2    172.31.1.0 [110/300] via 192.168.4.2, 02:11:20, FastEthernet0/0
O E2    172.31.0.0 [110/300] via 192.168.4.2, 02:11:20, FastEthernet0/0
O    192.168.11.0/24 [110/4] via 192.168.4.2, 02:11:20, FastEthernet0/0
O    192.168.98.0/24 [110/3] via 192.168.4.2, 02:11:20, FastEthernet0/0
     192.168.4.0/31 is subnetted, 1 subnets
C       192.168.4.2 is directly connected, FastEthernet0/0
O    192.168.99.0/24 [110/2] via 192.168.4.2, 02:11:21, FastEthernet0/0
O    192.168.20.0/24 [110/2] via 192.168.4.2, 02:11:21, FastEthernet0/0
     192.168.5.0/31 is subnetted, 1 subnets
O       192.168.5.2 [110/2] via 192.168.4.2, 02:11:21, FastEthernet0/0
     10.0.0.0/32 is subnetted, 1 subnets
O       10.0.0.1 [110/3] via 192.168.4.2, 02:11:21, FastEthernet0/0
     192.168.6.0/31 is subnetted, 1 subnets
O       192.168.6.2 [110/3] via 192.168.4.2, 02:11:21, FastEthernet0/0
     13.0.0.0/24 is subnetted, 1 subnets
C       13.13.13.0 is directly connected, Tunnel0
O*E2 0.0.0.0/0 [110/1] via 192.168.4.2, 02:11:21, FastEthernet0/0
My questions are why sh ip route shows route 3.3.3.3,4.4.4.4   learned both from OSPF and EIGRP  .
As  per my understanding sh ip route should show best routes in the  destination table but here it shows same route from 2 different  protocols.
MAhesh
Now when i do sh ip route on R3 it shows
HTH,
Nagendra
Hi Mahesh,
The routing table will show both EIGRP and OSPF
In this case 3.3.3.3 is learned via OSPF because you use the network command and also 3.3.3.3 is learned via EIGRP because you use the redistributed connected command under EIGRP, but the the active route in the routing table is the one with lower admin distance.  In this case it is OSPF (110).
Reza
Hi Mahesh,
sh ip route eigrp
sh ip route OSPF
When you do
sh ip route,
Reza
Hi Reza,
Thanks for reply back.
When you said  --
so when we do sh ip route it shows both the routes learned by OSPF and EIGRP - In this case both routes are there
Because 3.3.3.3  has Mask of /24  while using EIGRP and 3.3.3.3 ha smask of /32 while OSPF this is as per Nagendra above posts.
MAhesh
HTH,
Nagendra
Hi Nagendra,
Many thanks for great explanation.
Now all my queries are cleared.
Best regards
MAhesh
Hi Reza,
Many thanks again for helping me out.
Best Regards
MAhesh
