Redistribute Static Route on OSPF - Nexus 9372TX
utawakevou
Level 4
Level 4
Got a setup using two Nexus 9372 configured in a VPC domain (one of them as primary and the other as secondary), running OSPF and HSRP with  5 static routes configured on both
I want to redistribute  those 5 static routes on OSPF. Can someone point me to any example documentation
Deepak Kumar
Create a Access list for Static Routing
ip access-list standard 10
10 permit X.X.X.0 0.0.0.255
20 permit X.X.X.0 0.0.0.255
30 permit X.X.X.0 0.0.0.255
40 permit X.X.X.0 0.0.0.255
50 permit X.X.X.0 0.0.0.255
Create Route Map
route-map static-in-ospf permit 10
match ip address 10
set metric 200
set metric-type type-1
And now the redistribute commands
router ospf X
redistribute static subnets route-map static-in-ospf
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
8 Replies 8
utawakevou
Level 4
Level 4
Anybody willing to help out ?
Deepak Kumar
Go to the OSPF Process and type a command
redistribute static
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
I'm sorry that doesn't work with Nexus. Nexus require route-map to be configured and that's what I need help for with static routes. All /24 subnets
Deepak Kumar
Create Route Map
match ip address 10
set metric 200
router ospf X
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
Thanks, that helps. Use the following syntax
ip access-list static-routes
10 permit ip x.x.x.x 0.0.0.255 any
match ip address static-routes
set metric 200
redistribute static route-map static-in-ospf
Why my tried, it's not work?
# sho ip rou static
x.151.177.0/25, ubest/mbest: 1/0
    *via x.151.177.200, [1/0], 00:31:53, static
     via Null0, [191/0], 00:31:53, static
x.151.178.0/24, ubest/mbest: 1/0
    *via x.151.177.200, [1/0], 00:15:29, static
ip access-list GACL
  10 permit ip x.151.177.0/25 any
  20 permit ip x.151.178.0/24 any
ip prefix-list Gprefix seq 10 permit x.151.177.0/25
ip prefix-list Gprefix seq 20 permit x.151.178.0/24
route-map Groute-map permit 5
  match ip address GACL
route-map Groute-map permit 10
  match ip address prefix-list Gprefix
router ospf 100
  area 0.0.0.40 stub
  redistribute static route-map Groute-map
  passive-interface default
How should I do?
Thank you very much.
are you trying to redistribute the static routes into a stub area ?
I'm trying to redistribute the static routes from a stub area into backbone area.
