redistribution into eigrp
sakthicisco
hai alll,
i want to know wat wud b the metric wen redistributing isis into eigrp with the following in the attachment..
router A(config-router)redistribute isis level 1 metric 512 XX 255 1 1500
wat sud b there for delay?is it in tens of microsecon or simply microsecond?wat sud i configure....plz do help me....
thanks in advance
royalblues
Level 10
Level 10
Sakti,
Delay should be mentioned in 10's of microsecond.
http://www.cisco.com/warp/public/105/redist.html
though the exact question is not clear from the attachment but if you need a delay of 5ms, you need to configure the delay as 500 as 500 x 10us = 5ms
HTH, rate if it does
Narayan
thank u so much....
u guys r first forever wen someone is seeking help...
