Reduced Bandwidth on Cisco 3550
I upgraded my cable connection to 200mbps. I have an ASA5506x with a 3550 switch. When I connect a PC or laptop direct to an ASA port I get full 200mbps. But when I connect to one of the ports on the 3550  speed gets reduced to only 100mbps. I tried changing the speed/duplex with no luck. Has anyone aver come across this?
Thx
Francesco Molino
Your 3550 switch is only 100mbps. You can't go higher than that speed.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
I'll try a gig switch
Deepak Kumar
Cisco 3550 is having 100Mbps port only. This is a hardware limitation. Please upgrade your Switch with latest one, which can support 1Gbps.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
So basically there are various models for the Cisco 3550 that have specific hardware limitations. To verify which model you currently have you can run this command
Switch>show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA13, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 27-Feb-09 22:20 by amvarma
Image text-base: 0x80010000, data-base: 0x80570000
ROM: Bootstrap program is C2950 boot loader
Switch uptime is 0 minutes
System image file is "flash:c2950-i6q4l2-mz.121-22.EA13.bin"
cisco WS-C2950-12 (RC32300) processor (revision B0) with 20957K bytes of memory.
Processor board ID FAB0535Q22L
Last reset from system-reset
Running Standard Image
12 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:06:D6:AB:A0:40
Motherboard assembly number: 73-5782-08
Motherboard serial number: FAB0535BC1K
Model revision number: B0
Model number: WS-C2950-12
System serial number: FAB0535Q22L
Configuration register is 0xF
After you find the model number compare it with the below versions, this can give you a better indication of what your device can handle.
Cisco Catalyst 3550-48
WS-C3550-48-EMI
●  48 10/100 ports and 2 GBIC-based Gigabit Ethernet ports
●  1 rack unit (RU) stackable, multilayer switch
●  Delivers enterprise-class intelligent services to the network edge
●  Enhanced Multilayer Software Image (EMI) installed
●  Provides advanced IP routing
WS-C3550-48-SMI
●  1 RU stackable, multilayer switch
●  Delivers enterprise-class intelligent services and basic IP routing to the network edge
●  Standard Multilayer Software Image (SMI) installed, upgradeable to advanced IP routing
Cisco Catalyst 3550-24
WS-C3550-24-EMI
●  24 10/100 ports and 2 GBIC-based Gigabit Ethernet ports
●  EMI installed
WS-C3550-24-SMI
●  SMI installed, upgradeable to advanced IP routing
Cisco Catalyst 3550-24 PWR
WS-C3550-24PWR-EMI
●  1 RU stackable, multilayer switch; integrated inline power
●  EMI installed
WS-C3550-24PWR-SMI
Cisco Catalyst 3550-24 DC
WS-C3550-24-DC-SMI
●  1 RU stackable, multilayer switch, DC powered
Cisco Catalyst 3550-24 FX
WS-C3550-24-FX-SMI
●  24 100FX multimode fiber ports and 2 GBIC-based Gigabit Ethernet ports
Cisco Catalyst 3550-12G
WS-C3550-12G
●  10 GBIC-based Gigabit Ethernet ports and 2 10/100/1000 ports
●  1.5 RU stackable, multilayer Gigabit Ethernet switch
Cisco Catalyst 3550-12T
WS-C3550-12T
●  10 10/100/1000 ports and 2 GBIC-based Gigabit Ethernet ports
EMI Upgrade Kit
CD-3550-EMI=
●  EMI upgrade kit for all standard versions of the Cisco Catalyst 3550-24, Catalyst 3550-24 PWR, Catalyst 3550-24 DC, Catalyst 3550-24 FX, and Catalyst 3550-48 Switches
kind Regards
Jean-Pierre Roux
