Redundant connections config help
Justice918
First off i want to apoligize as i am not a big networking guy but somehow have been tasked with this project.
We have a single connections going from each floor of our building to a central server room.  Each floor currently has a single fiber connection " connecting them" i have run Ethernet cable from each switch on said floor back to the core switch in our server room " same one that has the fiber connection running to it".  With that being said i have found some configs with the help of good ol google to try and stumble may way through this process but am stuck.
below is a snip bit of the config that i have on the two devices and put onto the appropriate ports on said devices.  Any help is greatly appreciated as when i pull the fiber from one of the devices it does not fail over to the other Ethernet connection.  Thanks in advance .
#this is added to the switch devices them self
interface Port-channel1
 description uplink to 1st floor
 switchport trunk allowed vlan 1,70,71
 switchport mode trunk
#added to both fiber channels on each switch
interface tengigabitethernet 9/1
 channel-group 1 mode on
#added to both ethernet channels on both switches
interface GigabitEthernet 8/31
 channel-group 1 mode on​
Any help would be greatly appreciated and thanks in advance
actually you don't need to configure anything on the port channel interface itself. The below should be sufficient:
8 Replies 8
Hi ,
Thanks for the help just to be clear those should be the only commands i need to get the redundant connection working.  just ensure that i apply the lines to the correct device / ports etc.
Exactly, that is all the config you need. Just make sure that you use the exact same config on both devices connected to each other...
Hello
FYI - Due to possible inconsistencies it best practice for L2 Port Channel NOT to configured on the physical interfaces at all apart from assigning it to a Port-channel group
All the config SHOULD be performed on the logical port-channel which will then propergate that configuration down to the physical interfaces.
Kind Regards
Paul
So upon issuing these commands i now have lost connectivity to the switch that i am trying to build the redundant connection. Even after re-setting all port config to the original the switch will still not come back up / connect . Any advice my guy
Hello
Can you elaborate on the physical setup, it seems quite convoluted on what you are doing,
Note- you cannot have two separate switcha connecting into the same port-channel on the core, however you can have a switch connect to two separate cores switchs ( one virtual core) providing this is vss mec connection.
Kind Regards
Paul
Switch A is on floor A .. Core switch is on Floor B   .  We have a single fiber line and a single ethernet line running to said core switch from Switch A.  Core switch ports used Fiber line in tengig 9/1 ethernet in gig 8/34 " for example "  on Switch A ports used fiber line  1/0/1  ethernet 1/47   - I will add after adding the lines from a previous answer my switch is fulling offline and im having a heck of a time getting it back online - even after putting all port configs back to their original config.
Just a bit more info.  The fiber adapter on the switch that is down is showing no activity lights after adding the - channel-group ... on the core switch port that said fiber channel is going into.
