09-17-2020 10:20 AM
Hello
09-17-2020 07:42 PM
I might have found the answer on the Cisco 350 guide. dynamic LAG protocol
Link Aggregation Overview Link Aggregation Control Protocol (LACP) is part of the IEEE specification (802.3ab) that enables you to bundle several physical ports together to form a single logical channel (LAG). LAGs multiply the bandwidth, increase port flexibility, and provide link redundancy between two devices. Two types of LAGs are supported: • Static—The ports in the LAG are manually configured. A LAG is static if LACP is disabled on it. The group of ports assigned to a static LAG are always active members. After a LAG is manually created, the LACP option cannot be added or removed, until the LAG is edited and a member is removed (which can be added back prior to applying); the LACP button then become available for editing. • Dynamic—A LAG is dynamic if LACP is enabled on it. The group of ports assigned to dynamic LAG are candidate ports. LACP determines which candidate ports are active member ports. The non-active candidate ports are standby ports ready to replace any failing active member ports.
