Redundant links between switches
Phill Hodges
So in my building I have a switch closet on each floor with a stack of 3750's. Each floor switch stack has a single fiber link to the core switch (3750) in the server room. Both switches are L3 and I've configured the link between as a dot1q trunk. I would like to run another fiber cable to each switch closet for redundancy and increased throughput from each floor. Basically I want gi1/0/49 and gi2/0/49 on the floor switch to be bonded and gi1/0/4 and gi2/0/4 on the core switch to be bonded so if I lose a link, the switches will still operate. I am not sure how to go about setting this up. Can I just configure the new interfaces the same and connect them? or do I need to set up an etherchannel port group? or maybe something else? Thanks,
Bilal Nawaz
Hi Tom, typically you would create an etherchannel between your access switches and the core/distribution. You can use LACP for the negotiation of this (my preference). If the SVI sits on the access layer, then only a point to point L3 needs to be created between your collapsed core/distrbution and your access switch where traffic can be routed from and to the access switch
Layer 2 Example config below where the SVI sits on the Core/Dist:
interface po1
switchport
switchport mode trunk
interface gi1/0/49
switchport
channel-group 1 mode active
interface gi2/0/49
switchport
Layer 3 Example config below where the access switch is routing at the core:
interface po1
no switchport
ip address x.x.x.x x.x.x.x
interface gi1/0/49
no switchport
no ip address
interface gi2/0/49
no switchport
no ip address
Any questions about this, let us know.
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
14 Replies 14
Jon Marshall
Tom
What do you mean by this ?
Where is the routing between vlans being done ie. on each closet stack or the core.
Is it just one core switch or is a stack ?
Jon
The core switch has the WLAN vlans which are distributed to the floors. Each floor switch has a vlan for data and voice for that floor on it.
Core switch is a stack of 2 3750's
Bilal Nawaz
interface po1
switchport
interface gi1/0/49
switchport
interface gi2/0/49
switchport
interface po1
no switchport
interface gi1/0/49
no switchport
no ip address
interface gi2/0/49
no switchport
no ip address
Bilal
Bilal,
Thanks! Do I specify switchport trunk allowed vlan XX on the port-channel interface, the physical interfaces or both?
Only on the port-channel - make sure your physical interfaces are already under the port-channel before you do this :)
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just want to add that sometimes you should configure the port-channel and sometimes the bundled ports.  Also, there's some variety between IOS versions in how well port-channel configuration statements are "pushed" to the bundled ports.  (Later IOS versions generally work better.)
PS:
Tips:
  • Etherchannels use stack master's MAC, if you don't configure persistent stack MAC, loss of your stack master will cause your etherchannel to reset.
  • You might want to change the stack's default load balancing algorithm.
Bilal,
Thanks for your guidance on this, I was actually able to complete this a little more simply than your instructions. I based mine off http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/69979-cross-stack-etherchannel.html
FLOOR SWITCH:
int range gi1/0/X , gi1/0/Y
description link to core
switchport trunk allowed vlan A,B,C,D
exit
CORE:
description link to Floor
exit
I have tested this and the failover portion seems to work well, however if I do sh in po1 it shows Full-duplex, 1000Mb/s, link type is auto, media type is unknown
I was expecting it to be 2000Mb/s. Am I actually getting 2x1Gbps with LACP if both links are UP?
Hi Tom, you should see 2gb.
whats the output of 'show etherchannel summary' please?
ServerRoom_Int#show etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi1/0/1(P)  Gi1/0/7(P)
Disclaimer
Posting
That Etherchannel summary shows both links bundled and active.  Do the ports both show active traffic?  If so, it might be a cosmetic bug.  Again, some IOSs just don't deal as well with Etherchannel as others, although they all usually function fine.
Further to Joseph's comments, if you have traffic flowing through - what he describes as "show active traffic", the counters should increase. So you can do "show int gi1/0/1" as well as "show int gi1/0/7" to see the input/output statistics to determine if both are forwarding and receiving.
Exactly.
Yes I see traffic on both ports, so I guess all is good. Thank you both for your help with this!
Curious. Phil mentioned additional fiber cable not a pair in the same one. So physical characteristics might be different. Is that kosher ? What if I had one fiber link and combined it into port-channel with wireless bridge link ? My understanding is that's a no-no. Actually have that problem right now. LOL. Tx
