Redundant Routers Connection 2 ISP
amorsico7
Hello Guru's
I need your help about this network diagram,
Currently we have two ISP provider, (ISP-1 ISP-2 as shown in the drawing ) and functioning separately.
To optimize both ISP I want to make it redundant.
My plan set up is to connect router 0 and router 2 as well as Router 1 and Router 3 so that when one hardware ( router ) fail there are still a backup.
I am not very technical person about networking that’s why I decided to post my concern here because I believe that there are so many gurus member here that can help.
I need your advice on what would be the protocol/configuration that I need to apply to make my network setup happen.
Currently the hardware’s ( Router 0, 1, 2 and 3 ) are configured as follow. Very simple configuration but its working fine without any issue.
ROUTER0#
ROUTER0#show run
ROUTER0#show running-config
Building configuration...
Current configuration : 770 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ROUTER0
interface FastEthernet0/0
 ip address 172.17.32.200 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet1/0
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 ip address 161.126.44.193 255.255.255.252
router eigrp 7620
 network 161.126.0.0
 network 172.17.0.0
 no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.32.1
no cdp run
line con 0
line vty 0 4
 login
end
ROUTER1#show running-config
Current configuration : 753 bytes
version 12.2
hostname ROUTER1
 ip address 192.168.3.200 255.255.255.0
 duplex auto
 speed auto
interface Serial2/0
 ip address 161.126.44.194 255.255.255.252
 clock rate 2000000
router eigrp 7620
 network 161.126.0.0
 network 192.168.3.0
 no auto-summary
ip classless
no cdp run
line con 0
line vty 0 4
 login
end
ROUTER2#show running-config
Current configuration : 847 bytes
version 12.2
hostname ROUTER2
 ip address 192.168.0.200 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/0.1
 encapsulation dot1Q 10
 ip address 192.168.6.10 255.255.255.0
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 ip address 161.126.44.221 255.255.255.252
interface Serial3/0
 no ip address
 shutdown
interface FastEthernet4/0
 no ip address
 shutdown
interface FastEthernet5/0
 no ip address
 shutdown
router eigrp 7609
 network 161.126.0.0
 network 192.168.0.0
 network 192.168.6.0
 no auto-summary
ip classless
no cdp run
line con 0
line vty 0 4
 login
end
ROUTER3#show running-config
version 12.2
hostname ROUTER3
 ip address 192.168.2.200 255.255.255.0
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 ip address 161.126.44.222 255.255.255.252
 clock rate 2000000
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
router eigrp 7609
 network 161.126.0.0
 network 192.168.2.0
 no auto-summary
ip classless
no cdp run
line con 0
line vty 0 4
 login
end
Deepak Kumar
How many public IPs allocated you by ISP? Is ISP providing BGP synchronizing (neighbourship)?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
two IP's per ISP as you can see on the drawing above, i am not sure about BGP syncrhonization.
right now the two ISP provider are connected on two routers ( R0 and R1) with EIGRP and configure as redundant and its working fine now. if ISP get disconnected the ISP 2 will catch all traffic so there is no down time.
and i am not sure what protocol to use, how can i make those connection redundant using 4routers and 2 ISP providers.
my concern now is i will add two addtional router's as per drawing above to mitigate connection failure in-case of hardware break down.
thank you and hope you get what i mean, " sorry for the bad grammar"
As I understand the question. You can archive the same with HRSP configuration.
http://www.routerfreak.com/how-to-configure-hsrp-on-a-cisco-router/
Deepak Kumar
Deepak Kumar,
You will need minimally a /24 (class C) block of registered IP addresses and an ARIN administered BGP ASN. If you have the /24 already, then you need to apply to ARIN for the BGP ASN. If you do not have the required addressing, you would need to obtain such a block from one of the ISP's and a letter of authorization from them the indicated address can be advertised to a secondary ISP. Once you have obtained the class C block from one of the ISP's, then you can get the ASN from ARIN.
