Redundant Sup 6-E's in 4507R question
rshum
I'm considering using the Sup 6-E in some 4507RE switches. The Sup 5's I have now had a limitation regarding uplinks on the Sup cards where only 1 port on each sup was active at a given time with the second redundant port a standby. Is this the same case with the Sup 6-E?
Roland
Reza Sharifi
Roland
Hi Roland,
In Sup-6-E the ports on redundant Sups can be active at the same time.
Have a look at the data sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/prod_white_paper0900aecd806ed38a.html
Reza
Reza Sharifi
Roland
Hi Roland,
Reza
Thanks for the info and link, I was looking for something like that but couldn't find it.
This helped a lot. Would you have something like that for 6500 Sup720? Thank you.
