Regarding Cisco 2960-24T
김선명
Hi All
When I access the c2960 via console, I can't set backup interface.
please refer to below.
Model : WS-C2960S-24TS-S
Version :  (C2960S-UNIVERSALK9-M), Version 12.2(55)SE5
SW#1(config)#interface gigabitEthernet 0/23
SW#1(config-if)#
SW#1(config-if)#sw
SW#1(config-if)#switchport b
SW#1(config-if)#switchport b?
block
5 Replies 5
Francesco Molino
It should work. Could you confirm which license are you using on the switch? (show license)
If I remember, this switch has a Lan Lite and you need a minimum of LAN Base license,
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
I'm sorry for my late reply...T_T
well then, Can I use this feature on 2960X?
Yes you can once running lanbase
Mark Malone
Its running on lanbase on my 48TS 2960s
xxxxx(config-if)#switchport ?
  access         Set access mode characteristics of the interface
  autostate      Include or exclude this port from vlan link up calculation
  backup         Set backup for the interface
  block          Disable forwarding of unknown uni/multi cast addresses
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48TS-L   12.2(55)SE8           C2960S-UNIVERSALK9-M
xxxxxx#sh license
Index 1 Feature: lanlite
        Period left: 0  minute  0  second
Index 2 Feature: lanbase
        Period left: Life time
        License Type: Permanent
