Regular DHCP Binding Output
hillda01
Community Member
I want to output the dhcp binding information using a krontab every 1 hour but I can't see to work out the krontab schedule for hourly or the krontab won't do an hourly output.
This is the command that I've got and it works but I want it to run every hour
show ip dhcp binding | redirect tftp://IPAddress/_dhcp_binding.txt
Can anyone tell me how I can schedule it every hour or let me know an alternative suggestion as to
10 Replies 10
balaji.bandi
Instead why not use EEM Script for this :
below example help you :
http://darenmatthews.com/blog/?p=2223#more-2223
BB
Thanks - would this work on a switch?
Hello
Possibly try this, I haven't tested it but it should run at every minute past the hour on every day of week.
event manager applet DHCP
event timer cron cron-entry "1 1-23 * * 0-6"
action 1.1 cli command "enable"
action 1.2 cli command "show ip dhcp binding | redirect tftp://IPAddress/_dhcp_binding.txt"
action 1.3 cli command "end"
Kind Regards
Paul
I don't have
or
event timer
It's a Cisco 9300 switch I'm trying to configure it on
Hello
Not sure not tried eem on 9ks before try as i posted it?
Kind Regards
Paul
FYI
That cron timer sequence does work as expected , just tested it on IOS
Kind Regards
Paul
So is it....?
conf t
yes here is IOX XE reference in case if you required.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/configuration/xe-3se/3650/eem-xe-3se-3650-book/eem-policy-cli.html
Let us know any issue.
BB
Thanks for your help - I'll try it out and feedback with my findings.
