03-14-2019 02:41 AM
I have a C3650 Catalyst Swich. It has deleted the IOS and this is the output below. I need help to reinstall the IOS.
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch:
switch: dir flash:
Directory of flash:/
80801 drwx 4096 .
2 drwx 4096 ..
80803 -rw- 2097152 nvram_config
80809 drwx 4096
1271697408 bytes available (315781120 bytes used)
Thanks.
03-14-2019 02:53 AM
Hi there,
Copy the IOS bin file to a USB flash drive and from ROMMON boot off it:
boot usbflash0:<ios_filename.bin>
Once IOS is loaded up, TFTP/FTP the image back onto flash.
cheers,
Seb.
03-14-2019 03:02 AM
Use the Emergency Recovery proceedure and don't forget to "expand" the firmware when the switch boots up.
03-14-2019 04:06 AM
here the day to day steps : ( adding to other posts)
1. Copy your ios to the usb (USB format should be FAT32)
2.If you use USB slot0 then usb boot is
3.switch: boot usbflash0:/image-ios.bin
Once it booted and working / confirmation.
4. Copy the image from USB to Flash
copy usbflash0:/image-ios.bin flash:
5. Set Boot variable
BB(config)# boot system flash:/image-ios.bin
Verify image has been set properly in flash with "show boot".
Save by typing "write" and reload
