Reliability value on POS interface
    Hello Expert,
I have faced a problem on POS interface,
these are two interfaces back to back details:
POS at 7600 router:
sh int PO3/0/0
POS3/0/0 is up, line protocol is down
  Hardware is Packet over Sonet
  Description: STM4-To-1stCore-SH
  Internet address is 192.168.56.9/30
  MTU 4470 bytes, BW 622000 Kbit, DLY 100 usec,
     reliability 149/255, txload 1/255, rxload 1/255
  Encapsulation HDLC, crc 32, loopback not set
  Keepalive set (10 sec)
  Scramble disabled
  Last input 17:51:58, output 00:00:05, output hang never
  Last clearing of "show interface" counters 14:09:13
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  1 minute input rate 0 bits/sec, 0 packets/sec
  1 minute output rate 0 bits/sec, 0 packets/sec
     5061 packets input, 111294 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
              0 parity
     9 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     5096 output errors, 0 applique, 1 interface resets
     0 carrier transitions
POS at 12000 router:
POS0/2/3/0 is up, line protocol is down  (APS not Configured )
  Interface state transitions: 34
  Hardware is Packet over SONET/SDH
  Description: STM4-To-Permam
  Internet address is 192.168.56.10/30
  MTU 4474 bytes, BW 622080 Kbit (Max: 622080 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation HDLC, crc 32, controller loopback not set, keepalive set (10 sec)
  Last input 18:00:03, output 00:00:00
  Last clearing of "show interface" counters 14:53:18
     0 packets input, 0 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     5586 packets output, 120936 bytes, 0 total output drops
     0 output errors, 0 underruns, 0 applique, 0 resets
Would you please help to identify this issue ? what about reliability value ?
Ahmed
acampbell
Ahmed,
Forget about the Reliability conter.
Your main kissue is that both ends are in a
UP/Down state.
Have a read at this link.
http://www.cisco.com/en/US/tech/tk482/tk607/technologies_white_paper09186a0080094699.shtml#lineprotocol
Chech framing, clocking and scrambling
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hello Acsmpbell,
thanks for replying ...
actuaaly i have reloaded the SIP itself and cleared counters then POS interface backed normally.
durning the reload operation i got this log message :
Dec 26 20:06:13 UTC: %SNMP-5-MODULETRAP: Module 3 [Down] Trap
Dec 26 20:06:13 UTC: %OIR-6-REMCARD: Card removed from slot 3, interfaces disabled
Dec 26 20:06:13 UTC: %C7600_PWR-SP-4-DISABLED: power to module in slot 3 set off (Reset)
Dec 26 20:06:13 UTC: %C7600_PWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
Dec 26 20:06:28 UTC: %C7600_PWR-SP-4-PSNOREDUNDANCY: Power supplies are not in full redundancy, power usage exceeds lower capacity supply
Dec 26 20:07:18 UTC: %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 3/0
Dec 26 20:07:21 UTC: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
Dec 26 20:07:27 UTC: %SNMP-5-MODULETRAP: Module 3 [Up] Trap
Dec 26 20:07:27 UTC: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
SLOT 3: *Mar  1 00:00:08.811: %FABRIC_INTF_ASIC-5-FABRICSYNC_DONE: Fabric ASIC 0 Channel 0: Fabric sync done.
Dec 26 20:07:31 UTC: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
Dec 26 20:07:32 UTC: %DIAG-SP-6-RUN_MINIMUM: Module 3/0: Running Minimal Diagnostics...
Dec 26 20:07:37 UTC: %DIAG-SP-6-DIAG_OK: Module 3/0: Passed Online Diagnostics
what powe log does means ?
Why POS interface went down suddenly ?
Thanks.
Ahmed
