high current alarm for Nexus interface transceiver
wipronitin
I have a Cisco 5548 Nexus switch with 10Gbase-SR interface transceiver. This interface is connected to Server chasis.
The show interface transceiver details output shows High ++ alarm for Current. Additionally, i am getting output errors on this interface.
Can someone suggest what could be the reason for High alarm & also can it be the reason for high output errors.
How can this be corrected??
Nitin
Oleksandr Nesterov
Can you try to replace patchcords and try to connect other devices instead of your servers to confirm that tha SFP are ok?
Also try to connect current servers with other SFP to see whether the servers are not causeing this behavior.
HTH,
Alex
