VLAN Unnumbered Subinterfaces problem
Boris Krajnc
I have connected router Cisco 2851 (Ge0/1= LAN, Ge0/0= WAN) and switch Cisco WS-C2950G-48-EI . On router LAN interface I would like to create 30 subinterfaces (every subinterface for one user) and this subinterfaces should be unnumbered to Ge0/1. I would like to all users have IP from same subnet.  I configure router and switch but I can not access IP address configured on Ge0/1 from user on some VLAN (VLAN 1101 in my example). What I am doing wrong ? Please se attached picture and part of the configuration for better understanding.
interface GigabitEthernet0/1
description User subinterfaces
ip address 172.30.0.1 255.255.252.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1.1101
description User_1101
encapsulation dot1Q 1101
ip unnumbered GigabitEthernet0/1
ip nat inside
On Switch side I configure UPLINK interface (Fa0/48) wit mode trunk and allow all VLANs and port (Fa0/1) with mode access for VLAN 1101...
I also try to create "correct" subinterface configuration with IP address and it works, but that means in this case every user will have different gateway and I don't like it:
ip address 172.30.0.2 255.255.252.0
ip access-group 110 in
ip nat inside
Of course in this testing scenario User GW was 172.30.0.2/22
I assume routing is not problem because subinterfaces are directly connected or I don't understand something ?
Any advice will be very helpfull.
Thank you in advance
Boris
7 Replies 7
Reza Sharifi
In your configuration above, since you are creating a sub-interface for vlan 1101, than you don't need an IP address under the global interface.  You just need to put the IP under the sub-interface:
example:
duplex auto
speed auto
ip nat inside
and on the switch side you have already configured interface fa0/1 as trunk with dot1a as encapsulation which is correct.
This way, all your users on the switch access ports are part of vlan 1101 and this vlan is part of the trunk and the router is the default gateway for your users. The switch is layer-2 only. If the config is correct you should be able to ping from a host to the router's ip address.
Reza,
Thank you for your answer and hints but I can see that I didn't give enough clear informations what I want.
I would like that users from different VLANs belong to the same subnet and everybody  have one GW IP address. Maybe little strange but ....
I believe your way is working correct because I already test it, but I am curious if I can configure in my way ?
Boris
HI Boris,
I am curious as to why would you want to do that.  If they are all in the same subnet, why not put them all in the same vlan.  Using one subnet with multiple vlans will work, but makes things complicated specially when it comes to management and troubleshooting.  Usually you map a subnet to a vlan.
Reza
Hi Reza,
Indeed you are right. My first concept was subinterface for every user in network, then I start thinking about IP addressing and somehow become to solution with unnumbered interface. I agree there is no point to have separate VLAN's in same subnet. I will configure different subnet for single VLAN and I will have more control.
OK, I can say I have solution, but anyway, I am still curious how to configure unnumbered interface with subinterfaces. If I understand correctly manuals from here http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtunvlan.html#wp1059154 it should work like I already configure or..... ?
Reza, thank you for your kindnes and help.
Boris
Boris,
Glad to help!!
The concept of ip unnumbered is not a new concept.  Usually, it was used when organizations were short of IP addresses and this was one way to remedy WAN/serial interface IPs.  I have not configured it myself, but I am sure it will work since this feature goes back to earlier versions of IOS.
Reza
belorusandrey
Community Member
The presence of several subinterfaces can slightly increase CPU load on the router.
In your case I would be used PrivateVLAN.
Set up GW port on the switch as Promiscuous (Usually connects to a router. This port type is allowed to send and receive L2 frames from any other port on the VLAN) port and user ports as isolated.
Looks like this decision meets your requirements.
More information about PrivateVLANs you can find for example here
http://blog.ine.com/2008/01/31/understanding-private-vlans/
I agree with andriy. If you're trying to isolate one users' traffic from another it's much easier with private vlan on the switch than sub interfaces on the router.
