Reliable Static Routing Backup Using Object Tracking
Dcorning
Community Member
Can someone confirm if Reliable Static Routing Using Object Tracking is supported on the Cisco 3850 switch running IOS-XE?  If so, does it require IP Services licensing or will IP Base suffice?
If it is not supported on the 3850, what about the 3750X running IOS?  Again, would it require IP Services licensing?
Hello
CCO seems to suggest it does
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp/configuration/xe-3se/3850/iap-xe-3se-3850-book.pdf#page21
Res
Paul
Kind Regards
Paul
