Cisco switches 3560 need manual reboot after power outages
andy shutcha
Hi everyone,
In africa we have lot of power outages.
Working at a very big company with more than 300 switches can be challenging if you have to bring them up by manually rebooting few of them on the property.
The switches are directly connect via fiber using LH/LX SFP connector to a 4500 Core switch which is on a UPS and does not go down during the outage; only the access layer switches will then need manual reboot....
Please assist in having a permanent fix on this issue.
Thank you very much in advance.
hdussa
Can you post a "show boot" a "dir flash:" and "show ver".
Horst
@hdussa:
Here is the output :
sh boot
BOOT path-list      : flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
SW1#sh  dir flash:
Directory of flash:/
    2  -rwx        5436  Nov 21 2013 13:08:49 +00:00  vlan.dat
    3  -rwx        4749  Oct 10 2013 09:08:45 +00:00  config.text
    4  -rwx           5  Oct 10 2013 09:08:45 +00:00  private-config.text
    5  drwx         512   Mar 1 1993 00:10:16 +00:00  c3560-ipbase-mz.122-35.SE5
27998208 bytes total (18636800 bytes free)
SW1#sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
Image text-base: 0x00003000, data-base: 0x01100000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1)
SW1 uptime is 1 week, 1 day, 8 hours, 42 minutes
System restarted at 09:58:40 UTC Mon Feb 10 2014
System image file is "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin"
cisco WS-C3560-8PC (PowerPC405) processor (revision A0) with 122880K/8184K bytes of memory.
Processor board ID FOC1315V4LS
Last reset from power-on
3 Virtual Ethernet interfaces
8 FastEthernet interfaces
1 Gigabit Ethernet interface
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:25:46:DE:1F:00
Motherboard assembly number     : 73-10612-07
Power supply part number        : 341-0207-01
Motherboard serial number       : FOC13152YLK
Power supply serial number      : LIT13060H65
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3560-8PC-S
System serial number            : FOC1315V4LS
Top Assembly Part Number        : 800-28131-01
Top Assembly Revision Number    : E0
Version ID                      : V01
CLEI Code Number                : COM8C00ARA
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   9      WS-C3560-8PC       12.2(35)SE5             C3560-IPBASE-M
Configuration register is 0xF
SW1#
Please let me know if you need same output for another switch posing the same problem.
Thank you very much.
I'd be upgrading the IOS to something more recent, like 12.2(55)SE8.
