Reload command is not working for C9410R
We are trying to reload the entire chassis but reload(C9410R) is not happening. Below are the logs. FYI Here there are 2 SUP 1 module (Active & standby).
Could you please let me know reload command will do entire chassis or redundancy reload shelf need to be applied.
SWITCH# reload in 07:40
Reload scheduled for 15:10:44 CEST Tue May 30 2023 (in 7 hours and 40 minutes) by XXX on vty3 (X.X.X.X)
Reload reason: Reload Command
Proceed with reload? [confirm
SWITCH#sh relo
SWITCH#sh reload
No reload is scheduled.
Switch#reload
Proceed with reload? [confirm]
Switch1#
8 Replies 8
Mark Elsen
         1) Check and verify the current value of the configuration register
         2) Check logs when the reload command is attempted (look for additional info's and or errors if any) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I dont see any logs  when the reload command is attempted .
Leo Laohoo
Post the complete output to the command "sh version".  If this what I think it is, then it is a known bug.
I dont see configuration register value in this model(C9410r). Where i can check?
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.6.1r[FC2], RELEASE SOFTWARE (P)
SWITCH uptime is 1 year, 24 weeks, 6 days, 1 hour, 18 minutes
Uptime for this control processor is 22 weeks, 6 days, 4 hours, 36 minutes
System returned to ROM by SSO Switchover
System restarted at 08:02:10 CET Wed Dec 21 2022
System image file is "bootflash:packages.conf"
Last reload reason: EHSA standby down
 - Actually in IOS-XE , there is (another) equivalent for config register : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html , check your settings accordingly ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Issue the command "show version" and post the the entire output. The config-register value is at the very end of it.
Let me repeat what I am asking:  Post the complete output to the command "sh version".
If you are unwilling to following basic instruction(s), please raise a TAC Case.
check the time in router and do commnd again after 5 min from time you get and check
