Reload VSS Switch
suppawat11
Community Member
Hi everyone
            I have two switch 6800 serial run VSS. but i want to reload switch1 only no reload switch2
How to reload only switch1 or cli. i try used plug console port it's reboot both
Mehdi Behzadpour
Frequent Visitor
Frequent Visitor
actually that depends on which switch is Actvie and which one is standby.
by the way you can check that with commands like "#sh switch virtual" or "#sh redundancy states".
if you want to reload only the standby switch, you can use "#redundancy reload peer" command.
and if you want reload the active switch, you should force VSS to switchover from Standby to Active, with this command "#redundancy force-switchover".
Please rate if it was Helpful.
6 Replies 6
Hi  @suppawat11
This is for 6500 but you can try in 6800.
Reloading the Cisco Virtual Switching System and Its Members
It may sometimes be desirable to reload the entire system or to reset individual members of the Virtual Switching
System. You can perform these tasks through the console of the active virtual switch.
If you need to reload the entire Cisco Virtual Switching System (both active virtual switch and standby virtual
switch), the following command achieves this reload:
vss#reload
Proceed with reload? [confirm]
Reloading a Member of the Cisco Virtual Switching System
It may be more desirable to reload a member of the Cisco Virtual Switching System rather than the entire system.
You can accomplish this reloading in multiple ways.
You can reset the active virtual switch in two ways. First, you can issue the command redundancy forceswitchover,
which essentially forces a SSO or RPR switchover from active to standby, reloading the previous
active virtual switch in the process:
vss#redundancy force-switchover
This will reload the active unit and force switchover to standby[confirm]
Preparing for switchover.
You can also use the redundancy reload shelf command, where either Switch 1 or Switch 2 can be specified:
vss#redundancy reload shelf 1
Reload this shelf [confirm]
You also have two options to reset the standby virtual switch. First, you can use the same command as before,
replacing the switch ID with the switch ID of the standby virtual switch:
Reload the entire remote shelf[confirm]
Preparing to reload remote shelf
Alternatively, use the command redundancy reload peer to reload the standby virtual switch:
vss#redundancy reload peer
Reload peer [confirm]
Preparing to reload peer
-If I helped you somehow, please, rate it as useful.-
It is an old topic but I'm searching for reliable information about VSS reloading options.
Depending of documentation and your answer for example, I don't find the same options.
I had differents readings:
- C6500 VSS sup-6t : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-4SY/config_guide/sup6T/15_3_sy_swcg_6T/virtual_switching_systems.pdf
- C4500X VSS : https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/catalyst4500/XE3-10-0E/configuration/guide/xe-310-cg.pdf
Can someone point out a definitive answer about these commands on VSS (in a design with a single sup per chassis) ?
- redundancy force-switchover: more than switchover on standby supervisor, does it reboot the previous active node ? if yes, the full chassis or only the supervisor
- reload: 1) if entered on line vty of active node, does it reload the full VSS system ? both supervisor of each node ? 2) if entered on console of active chassis, is it the same ? or does it reload only the sup of the active chassis (from its console) ?
- redundancy reload shelf: it is expected to reboot the whole pair of nodes, not only both supervisors but all line cards as well. Isn't it ?
Reza Sharifi
If switch-1 is the primary device, there are 2 ways to do this:
1-redundancy reload shelf 1
2-redundancy force-switchover
The second option make switch-2 the primary device and reloads switch-1.
Mehdi Behzadpour
Frequent Visitor
Frequent Visitor
Jerome BERTHIER
Level 7
Level 7
- redundancy force-switchover: more than switchover on standby supervisor, it reboots the previous active node. Does it reboot the full chassis or only the supervisor ?
The most "efficient" way for the active Sup card to hand over to the secondary Sup card is a reload of the entire active chassis.
The "reload" command may reboot both chassis.  NOTE:  I said "may".  Depending on the situation where a memory leak or CPU hog incident is currently happening and one (or both) supervisor cards will "refuse" to reboot and manual intervention may be required.  Again, rare case.  I've only experienced this twice.
Frankly, it is better if someone explains what is the current situation so we can help and not shoot in the dark.
