Remember
Hi.
Just remember.
To add the switch in VTP domain, it must be VTP Transparent and so i change to VTP Client. Correct?
The configuration revision number of the switch must be the lower configuration revision number of the domain. In order to make the revision number equal to zero, BEFORE you plug the switch in the network, you must set the vtp mode to transparent and then revert to client:
vtp mode transparent
vtp mode client.
I hope this helps.
Best regards.
Massimiliano.
