% Remove layer 3 binding first
Shannon Sutter
Level 4
Level 4
I'm trying to remove "no pri-group timeslots 1-24 service mgcp" on a Controller T1 from a 2621MX Router IOS 12.3(11)T and i'm getting "% Remove layer 3 binding first". I can't really remember how to do this. If you guys knows the steps please let me know.
This is the Controller T1 config
controller T1 1/0
shutdown
framing esf
linecode b8zs
Thank you,
Zeek
Try this:
int s0/0/1:23
3825-A(config-if)#no isdn bind-l3 ccm-manager
3825-A(config-if)#contr t1 0/0/0
3825-A(config-controller)#no pri
It works!
Thank you,
Zeek
AlejoSan
Frequent Visitor
Frequent Visitor
In controllers E1 it is the same procedure:
RT(config)#interface serial 0/0/0:15
RT(config-if)#no isdn bind-l3 ccm-manager
RT(config-if)#exi
RT(config)#controller E1 0/0/0
RT(config-controller)#no pri-group timeslots 1-31 service mgcp
RT(config-controller)#end
