Renumber Cisco 2960X Switch | Remove Provision
CoachChan
Hello Everyone,
I have reviewed multiple posts but no luck renumbering this 2960X switch. My goal is to take a switch that has been removed from a stack and make it a standalone switch. After the "write erase" command, it still kept the stack provisioning and gi2/X/XX. I have tried "no switch 2 provision" and "switch 2 renumber 1 provision" with no success. Am I missing something here?
#show ver
512K bytes of flash-simulated no-volatile configuration memory.
Base ethernet MAC Address : 2C:31:24:F9:51:80
Motherboard assembly number : 73-16691-06
Power supply part number : 341-0527-02
Motherboard serial number : FOC210225JG
Power supply serial number : DCB20316016
Model revision number : N0
Motherboard revision number : A0
Model number : WS-C2960X-48FPS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC210156LS
System serial number : FCW2102BAKV
Top Assembly Part Number : 68-100469-02
Top Assembly Revision Number : A0
Version ID : V05
CLEI Code Number : CMMLN00ARD
Daughterboard revision number : A0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 2 52 WS-C2960X-48FPS-L 15.2(2)E5 C2960X-UNIVERSALK9-M
Switch#show switch detail
Switch/Stack Mac Address : 2c31.24f9.5180
H/W Current
Switch# Role Mac Address Priority Version State
*2 Master 2c31.24f9.5180 13 4 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
2 Down Down None None
2 Accepted Solutions
M02@rt37
Hello @CoachChan
Steps to renumber and reset 2960 switch to standalone mode:
1. Remove Stack Provisioning
Switch# no switch 2 provision
2. Renumber the Switch
Switch# switch 2 renumber 1
3. Erase the Configuration
Switch# write erase
4. Reload the Switch
Switch# reload
After the reload, the switch should come up as a standalone switch with default interface numbering.
Best regards
@CoachChan
Commands under config-terminal...
Best regards
5 Replies 5
M02@rt37
Hello @CoachChan
Switch# write erase
Switch# reload
Best regards
Thank you for the quick reply M02@rt37. As you can see below, I have tried these commands and received errors. This is what other posts said to attempt as well.
@CoachChan
Best regards
Well, that is truly embarrassing, thank you so much for your help. I will be turning in my resignation letter now....
Thank you and have a great day.
You're so welcome @CoachChan
Best regards
