REP works with Non-Rep Switch issues
silvio.lui
I've a ring topology where run REP with Cisco ME-34xx and works fine. However I deployment others 'non-REP' switches in this ring. After do it, a fail betwen non-REP switches, dosen't change the REP topology and keeps the Aternated port in Block state, and isolated non-REP switch. I've used "edge no-neighbor" in the edge non-REP, but as the interface that goes down isn't directly connected, REP doesn't recognize the topology change.
How I can use REP in this kind of situation?
Silvio Silva
BrianSekleckiGE
Were you ever able to solve you problem?
What version of Spanning-Tree were you running on the Intermediary non-Rep switches? PVST+ ? RSTP+? MST?
Share your network topology ?
debug rep?
debug spanning-tree?
