Bookmark
Subscribe
1123
Replace a Cisco 6800IA switch from an Instant Access client stacking
richter5087
Currently I have two Cisco 6800IA in stack mode and I have associated with the number FEX 100 to the parent switches, each 6800IA has an uplink to the parent switches. I need to replace the one of the two.
Could you please let me know the process in order to replace a failure Cisco 6800IA switch from an instant Access stacking?
Unable to find any related resource online, please share if you have any.
Thanks in advance, guys.
balaji.bandi
May be good to have small diagram - if everything dual homed connection, you can easily replace the one you thinking to replace.
If any devices connect to single homed that will have outage when you replacing the switch.
check below some reference and guide lines :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6800ia-switch/white_paper_c11-728265.html
BB
balaji.bandi
BB
Thanks a lot!.
Consider dual home across stack members? If so, how I going to remove one of the stack member and add this to another fex as stack member? This is what I am trying to do.
Hope to hear from you again.
Same way we do the when the device Fault and we get RMA and replacing the Faulty one - there is no change in that steps ?
above document help you.
BB
Noted. Will try it out.
Thank you.
