Replace default getway of firewall to swith
tech44048
Hi Community,
We need to switch between adress of ASA and MS-250 we need to give the address of ASA (192.168.1.1) to MS-250 (192.168.1.3) and adress of MS-250 TO ASA
-We have intervlan (van 1,30,20,40) managed by MS-250 Switch
-We have a server that takes static IP and take 192.168.1.1(address of ASA )as gateway IP
-In ASA we create rules for exchange server (open port: pop/imap/SMTP), if we change the gateway, the rules still work?
We need our server and device in vlan 1 go through MS Switch not the Firewall
Thank you
5 Replies 5
balaji.bandi
Then point the device to Switch as a gateway, add a static default route on switch  towards ASA.
From ASA add static route entries for 192.168.1.0/24 towards switch IP 192.168.1.3
Switch static route 192.168.1.1 (ASA)
device gateway 192.168.1.3
BB
Hello
Can you post a topology diagram please.
Kind Regards
Paul
Hi Paul,
to not change the default getway in all the server and device that take static rout ,just we need to replace ip of ASA(current getway192.168.1.1) with (MS-250 switch192.168.1.3)
Thank you
thank you for the diagram - @Giuseppe Larosa suggests another option - other than my default reply.
BB
Giuseppe Larosa
Hello @tech44048 ,
a clean design would require an additional VLAN like VLAN 50 for ASA to switch communication
VLAN 50 192.168.50.1/24 on ASA side and 192.168.50.2 on MS250 side
ASA ---- VLAN 50 ----    switch MS250 ---- VLAN 1-40
on ASA you will have
route 192.168.1.0 255.255.255.0 192.168.50.2 inside
route 192.168.20.0 255.255.255.0 192.168.50.2 inside
route 192.168.30.0 255.255.255.0 192.168.50.2 inside
route 192.168.40.0 255.255.255.0 192.168.50.2 inside
on switch
ip route 0.0.0.0 0.0.0.0 192.168.50.1
Yes with the proposed setup the server will have def gateway 192.168.1.1 on switch and switch will route to ASA on new VLAN 50
Hope to help
Giuseppe
