Replace MS120 with MS130
I want to replace the device from MS120 to MS130.
I've checked a few methods.
1. Switch clone
2. “Replace” from inventory
I'm not entirely sure, but it seems like the above two methods only work between identical devices.
I want to keep all settings exactly as they are IP, hostname, location, etc.
Any good ideas??
Philip D'Ath
Meraki Community All-Star
You are correct.
6 Replies 6
aleabrahao
To be honest, I find replacing a device on the Meraki so simple.
You can simply replicate the configurations to the new switch, test them in parallel, and then plan the replacement.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
This is not the same device.
Can I clone the settings from MS120 to MS130?
I don't think it's possible.
When I say replicate, I really mean manually configuring it. Meraki isn't that complicated and doesn't have many settings.
Philip D'Ath
You are correct.
Is the only way to reconfigure all the settings from the old switch on the new one?
Is there no better solution?
