Replacement commands for attach module, session module, or remote
LuensmannIT
Level 2
Level 2
Hi, there
I've a couple of C9407R switches (Version 17.9.3) with installed standby supervisor engine.
I would like to attach to the console of these standby subs.
With WS-C4507R+E switches i can use the commands "attach module 4", "session module 4, or "remote login module 4" to gain access.
I couldn't find these commands on the metioned switch / software version.
Does anybody know replacement commands to access the standby supervisor engine?
HOSTNAME#attach module 4
Connecting to standby virtual console
Type "exit" or "quit" to end this session
HOSTNAME-standby-console#
balaji.bandi
how below one (is this what you looking ?)
Device(config)# redundancy
Device(config-red)# main-cpu
Device(config-r-mc)# standby console enable
BB
LuensmannIT
Level 2
Level 2
I'm not sure if i'm looking for this.
Even if i set this command, i don't see a command to connect to the standby / secondary / slave sub from a ssh session to the primary sub?
My question is not about enabling the physical console port on the standby sub.
I got it, you looking tranditional way to connect to session to module like old Cat 4500/6500
unfortunatly not tested myself..(apologies)
BB
