Replacement Suggestions
Alexios
Hello Experts
An easy question,
Can you please suggest some replacement models for the models below which are both tagged as "end of life"
  1. WS-C3750G-12S
  2. WS-C2960G-24TC-L
Thank you!
Seb Rupik
Hi there,
If you look in the EOL notice it will suggest a replacement switch. Due to the age of your switches you have to make a few jumps:
2960G -> 2960S -> WS-C2960X-24TS-L
3750G -> 3750-X -> 3850 ->  C9300-24S
(EDIT: just checked the 9300 line up and there is a 24 port SFP switch)
cheers,
Seb.
5 Replies 5
Seb Rupik
Hi there,
cheers,
Seb.
Mark Elsen
 - Whilst not a direct answer you may also align your needs with :
                  https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you both!
Scott Hodgdon
Alexios,
For 2960, you should look at Catalyst 9200 / 9200L : https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html . While 2960X is also available, 9200L / 9200 is newer and will have a longer life than 2960X. The pricing should be similar.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking Group
Thank you Scott
Can you please direct me on where can I get some prices for these models in Greece?
